Old 02-24-2011, 12:21 PM   #1
justin_nelson
Is this the right spark plug?
I have a 250 inline 6 and went to local parts store and told them i needed plugs and this is what they gave me. They are the same overall length but the threads are longer than the ones that were in it. they thread all the way in but i just want to make sure they arent going to be hitting anything inside because the threads are longer.
thanks for all your help
justin
and heres a pic of my freshly painted motor
justin_nelson is offline   Reply With Quote
Old 02-24-2011, 12:28 PM   #2
Mike J
vw guy & now c-10 guy
Mike J's Avatar
Re: Is this the right spark plug?
I can't see the pics on the computer here at work- but you don't want the electrode end to be too long- it could possibly come in contact with the piston, and that won't be good. I would make sure that got the part number correct for your application.
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-24-2011, 12:33 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
I would get the number off the old plug and cross reference or get the same ones. Make sure of the year of the engine and if you are running HEI or not.
Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-24-2011, 01:34 PM   #4
Wrenchbender Ret
They changed the length of the threads on these engines around 1970 to the shorter plug. Often the older heads were put on a later engine. Check the length in the head. Also the longer plugs had a flat seat & used a gasket.
Wrenchbender Ret is offline   Reply With Quote
Old 02-24-2011, 02:50 PM   #5
camrycurt
camrycurt's Avatar
x2 on the cross-referencing. It took me three tries to get the right plugs for my new truck because the engine is not original and is from some old car, etc., etc.
IIRC, the Autolite website had a really good cross-reference and lookup feature that helped me a lot when I was trying to find the right plugs for my engine.
Good luck! Your engine looks great by the way.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
