02-24-2011, 12:46 PM | #1 |
292 or 250
i have a 63 c10 , both motor mounts are in same place, the passenger side is the same as driver side, does that make it a 250?
Ich möchte vroom vroom |
02-24-2011, 01:06 PM | #2 |
Re: 292 or 250
230...I don't think they offered the 250 till 1966, or at least that's when it became standard. But if that's the case then the motor mounts are the same
02-25-2011, 12:54 AM | #3 |
Re: 292 or 250
measure the side plates on the passenger side of the motor. THe 292's plates are bigger than the 230/250 motor. I'll measure mine on the 292 and you can compare.
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
02-25-2011, 01:02 AM | #4 |
Re: 292 or 250
The 292 lifter plates are 6"x13" and the 230 lifter plates are 4"x13". all sizes are approx coz it's fricken cold and dark out there tonight. lol
02-26-2011, 08:11 AM | #5 |
Re: 292 or 250
Thanks, i will measure mine and see when i can, thanks for the input
02-26-2011, 08:44 AM | #6 |
1961 crewcab
Re: 292 or 250
easiest way to tell the 292 the passenger motor mount is in front of the fuel pump. the 250/230 the fuel pump is in front of the mount.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
