02-24-2011, 03:23 PM | #1 |
Changing Diff Gear Oil ?
Does anybody know the capacity of SAE90 gear oil is in a 72 stock 307 geared rear differential. I can't find a drain plug so I guess options are to siphon out old oil or crack diff cover.
02-24-2011, 03:28 PM | #2 |
Re: Changing Diff Gear Oil ?
yup pop the cover it gives u a chance to inspect the gears anyway. 2 bottles of 90wt should do it
02-24-2011, 04:07 PM | #3 |
Big Red - Now its a SWB!
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
02-24-2011, 04:55 PM | #4 |
Moderator
pop the cover and drain. install new gasket. fill until the fluid reaches the bottom of the filler hole.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-24-2011, 04:58 PM | #5 |
use synthetic
