Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-24-2011, 03:30 PM   #1
Chevysdominate
Chevysdominate's Avatar
WTB: 64-66 headlight, engine wiring harness
I'm looking for a headlight wiring harness, engine wiring harness and the harness that goes from the cab to the headlight harness at the front radiator support. This is for a 1965 with gauges and not warning lights. Thanks
Chevysdominate is offline   Reply With Quote
Old 02-24-2011, 05:25 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: WTB: 64-66 headlight, engine wiring harness
are you on a serious budget? I ask because these are available through many vendors here on the board. also Classic Parts is a good place to shop alos.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-24-2011, 05:30 PM   #3
JimmyFloyd
I have the headlight harness off a 65 or 66 Big truck, which should be the same as the smaller ones. Will get a picture for you. $25 shipped work for you?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 02-24-2011, 05:49 PM   #4
Chevysdominate
No, I'm not on a real strict budget, but I'm going to end up hacking both harnesses up for a motor swap. I don't want to spend much money on something that ill be almost completely rewiring anyway. Although i did find the engine harness for a reasonable price. So i may buy that harness new. As for the cab to rad support and headlight harness they want a good deal more.
Old 02-24-2011, 05:51 PM   #5
Chevysdominate
Does that come with the cab to radiator support harness too? Get me a pic I'm interested either way. Thanks
Old 02-24-2011, 05:55 PM   #6
JimmyFloyd
It comes with the plug, but the wiring rubbed through on the radiator support from an aftermarket horn that was added. There is a 65 C10 here though I can check to see if I can grab it from. Probably would be about the same price.
