Old 05-03-2002, 09:12 PM   #1
sider68
sider68's Avatar
Post rust bubbles
i have an 81 p u with rust bubbles on the box.they are not through.i have never had any luck trying to fill something and it not show up in finished paint job
sider68 is offline   Reply With Quote
Old 05-04-2002, 08:23 AM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
If it is a bubble it is rusting from the inside and the only way to get rid of it is by cutting it out and replacing it. If you want to slow down the rust all you have to do is clean out the inside of the box (2 panels). Just open your gas door and remove the plastic shield inside there and use a hose to spray above the wheel wells. You will be amazed whats in there.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
