02-24-2011, 08:04 PM | #1 |
Lesson Learned
OK here we go,as you might know ,I bought a 72 blazer (39 YRS OLD).I love these Blazers,that's why I bought another one as a twin to the one I tore apart 15-20 Yrs ago.It needed a radiator , so i got a new one.Thought i replace the rad support ( RUST),so I bought one .then it all started, See (SNOW BALL EFFECT).Replaced water pump/fuel/belts/t-stat.I tryed to label all parts and put in sandwich baggies,which I did.The thing i didn't do is wright down the order of what went first or last.So after installing things I had the Battery tray left? Whoops rad is in and full of antifreeze,I cannot put the side bolts in without taking this apart again .
SO AS YOU DISASEMBLE THINGS /LABLE /AND MARK IN ORDER AS YOU TAKE APART,SO YOU CAN RE-ASSEMBLE WITH OUT TAKING APART AGAIN. ALSO AFTER MARKET (CRAP) DONT LINE UP THAT EASY AFTER ONE BAD BRAKE LINE /NOW TRANS LINES ARE LEAKING,IAM NERVOUS ABOUT THE REST OF THE LINES.
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) Last edited by 2003 silverado; 02-24-2011 at 08:07 PM. |
02-24-2011, 08:10 PM | #2 |
Re: Lesson Learned
more pics
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
