Old 02-24-2011, 11:12 PM   #1
slaminum69
slaminum69's Avatar
63 grille support assembly
Ok Guys, i finally got an original 63 grille and loving it. But Now i have a question regarding the grille support assembly, (The PO hacked up the originals to accommodate a reproduction grille) so the question is which of the years will work the 60-61 or 64-66? any advice is welcomed, Thanks for all the help in advance.
Dennis N.
USN Ret.
Patriotism is your conviction that this country is superior to all other countries because you were born in it.
slaminum69 is offline   Reply With Quote
Old 02-25-2011, 12:47 AM   #2
65stepside
65stepside's Avatar
Re: 63 grille support assembly
I'm pretty sure they're all the same. I've put a 1960 grille on a 1965. Both half tons.
J
1930 Olds 5 Window Coupe
1960 Chevy 1/2 Short Stepside on 1965 Frame 350/350
1960 Chevy 1/2 3'' Chop Short Stepside "FOR SALE!!!"
1966 Toronado
1971 Cutlass
1972 442
1978 Chevy 1/2 Long Fleetside
2001 Dodge 2500
65stepside is offline   Reply With Quote
Old 02-25-2011, 09:49 AM   #3
slaminum69
slaminum69's Avatar
I appreciate the help 65 stepside, I guess the reason i ask is because I have a set off a 64 and they don't match up to the grille. Its the two black brackets that attach the grille and headlights to the actual grille support on the truck. Unless I am doing something completely wrong. Thanks again
Dennis N.
USN Ret.
Old 02-25-2011, 04:09 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
If I remember correctly the grill supports for Chevrolet are 1960-62 then 1963 and finally 1964-66. The difference is the location of the grill mounting holes.
Old 02-25-2011, 04:13 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Bingo! There is also a separate 62 support. That's why you often see the grill supports with many different holes drilled into them by previous owners.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-25-2011, 05:38 PM   #6
slaminum69
slaminum69's Avatar
That is what I thought as well just wanted to make sure, I appreciate everyones input on this issue! By the way does anybody have some 63 brackets! Thanks
Dennis N.
USN Ret.
