firestone air bags
I've been searching and cannot find if anyone has installed the firestone air bags in the rear of a 66 series C10. I had them in a newer dodge dually and loved them for towing.
I've found plenty of info on dropping the suspension with air bags but nothing for the basic bags for the back. |
Re: firestone air bags
I'm going to put some on my truck just gonna fab it up to work.
Member of the longbed union.
I had them on my 64 lwb and didn't have any problems. They road really good, just replaced the springs.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#5 | |
![]() http://kieth.smugmug.com/Trucks/66-G...28724026_wdaD6 They were easy to install and gave me the ride and ride height control that I was after. I am planning on dropping the 65 chevy in the front and rear and will go with bags all around on it. Thiss 66 GMC is going to be a daily driver so I wanted to keep it simple. Last edited by kieth; 02-25-2011 at 10:40 AM. |
#6 | |
It's Better With Nitro
#7 | |
I"m going to be pulling a trailer and don't want the springs to sag. I also have noticed the front end sagging a little bit with the 350 engine in it and want to address that as well. |
When I bought my truck there wasn't any kit on it. Just a c-notch kinda, and bags replaced where the springs were.
My buddy that had the truck just drilled holes in the frame and in the arms for it to bolt to. I didn't have any problem lifting or lowering at all. There are several vendors on here that sell rear kits. Porterbuilt is one. He can answer anything you might have about it. CPP sells kits too. You can check out my build thread to see pics of it. I dont recommend to do it like my truck was in the rear. You need a spacer between the bag and frame or it will rub. I just wanted to show you what not to do. But it did ride good.
#9 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 02-25-2011 at 03:38 PM. |
http://www.brotherstrucks.com/prodin...number=ABK6772
I just found this at Brothers. Does anyone have this kit installed on their truck? |
that kit would work, but it wont allow you to be able to change the ride height of your truck. It's meant to be used with the stock springs to help carry a heavy load.
X2...it's a helper spring/air assist kit. But, it sounds like this is similar in function to what you mentioned in your original post about the system on your Dodge dually.
