Old 02-25-2011, 12:18 AM   #1
jojoman
converting back
i got a 87 but the guy who i bought it from took the tbi off and put a carb is it hard to convert wires well they look like they there, would you use a used intake and tb also injectors like from pick part Name:  Picture 008.jpg
Size:  74.7 KBthis plug comes out the fire wall it has a blue and pink wire cut off the rest of them dont know what they for the last 2 pic are same plugs different angles
Size:  21.7 KB also where is the ecm located at ther one that looks like it under dash behind glove comp. but it only has one plug and it goes straight to firewall
jojoman is offline   Reply With Quote
Old 02-25-2011, 06:05 PM   #2
jojoman
Re: converting back
no any one
Old 02-25-2011, 06:11 PM   #3
Jonboy
Slots go on anything!
Re: converting back
That doesn't look like an '87 wiring harness to me. The plug in the last pic looks like a TCC plug, should go to the trans. The solenoid on the firewall looks like a vacuum switch for the TCC, '87 should not have had this; TCC is controlled by the ECM. The middle picture plug looks like it might be to a diverter switch on the AIR injection.
1974 Jimmy- 5.3/4L80e/NP241
