Old 02-25-2011, 11:16 AM   #1
daverod
SSN 706
daverod's Avatar
89 s10 frame?
Would a 89 s10 reg cab long bed frame /running gear work for putting a 52 3100 on it? Would I have to cut the frame?Thanks
daverod is offline   Reply With Quote
Old 02-25-2011, 01:59 PM   #2
62ChevyII
Re: 89 s10 frame?
Yes, that is the correct wheelbase S10 for a donor for the 52 3100 truck. The only cutting you'll need to do is a little off the frame horns up front and a little of the rear frame rails to clear the back edge of the bed.
My S-10 swap thread: http://www.killbillet.com/showthread.php?t=16296
62ChevyII is offline   Reply With Quote
Old 02-25-2011, 02:24 PM   #3
one wing angel
one wing angel's Avatar
Re: 89 s10 frame?
Hi Daverod, if you are looking for a definitive guide to doing this frame swap,try doing a search for the thread "S10 frame swap" on the H.A.M.B.
I know the guys on this message board are really great and eager to help, but there is a TON of info. there that someone took a great deal of time to post. Just view it as another resource. We can never have too much info. can we?
Good luck with your project...John
one wing angel is offline   Reply With Quote
Old 02-25-2011, 02:35 PM   #4
one wing angel
Re: 89 s10 frame?
Hello 62CHEVYII, I just had a quick look at your build thread.There,s a ton of good stuff going on there. Thanks for the post and good luck with your project. I have the twin to your truck and am planning to use an S 10 frame also ,but am going to extend the cab about 14". Long wheelbase frame should work out O.K. Not full bore into the project as yet, still gathering up pieces and trying to finish a '55 Chevy frame -off . If it would just warm up a bit here. ( it,s still -25C) Hard to get motivated when your teeeth are chattering........ John
Old 02-25-2011, 05:16 PM   #5
63 & 64 Bowties
and a few others
Re: 89 s10 frame?
I didn't know you were over here now. Welcome.
I've talked to you over at RatRodsRule a few times. I'm ZippyDoDog over there.
Actually, I shouldn't even be talking to you.... I'm still mad at you for selling your truck
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-25-2011, 05:29 PM   #6
MrDude_1
Re: 89 s10 frame?
Originally Posted by one wing angel View Post
...planning to use an S 10 frame also ,but am going to extend the cab about 14"...
the extended cab frame would work great for you then... im curious to your plans on how you're extending the cab.. behind the door, making the door larger? etc...
any pics or drawings of your plans?
MrDude_1 is offline   Reply With Quote
Old 02-25-2011, 05:40 PM   #7
daverod
SSN 706
daverod's Avatar
Re: 89 s10 frame?
thanks guys
Old 02-25-2011, 06:04 PM   #8
62ChevyII
Re: 89 s10 frame?
LOL, yeah eventually maybe I can build one I can keep. That racing bug is an ugly thing and eats a lot more money than old trucks. I should just stick with old trucks!
Old 02-25-2011, 06:28 PM   #9
63 & 64 Bowties
and a few others
Re: 89 s10 frame?
For anyone who hasn't seen 62ChevyII's build, check out how he did his bed floor. I wish I had seen it before my S-10 went to the crusher. Or even better, maybe we can talk him into posting a pic of it here.
Last edited by 63 & 64 Bowties; 02-25-2011 at 06:29 PM. Reason: felt like havin' a peanut butter & jelly sandwich
