02-25-2011, 12:34 PM | #1 |
Lets see some pics of oversize knobby tires
I'm getting ready to put new tires on my 71 GMC 4x4. They will be mounted on 15 x 8 steelies. I'd really like to go with 35s but don't know if I'll have the clearance to get in my garage, especially if I have to lift from the current stock height to keep them from rubbing. I'm sure 33s will be fine as far as clearance goes but not sure if they will give the look I want. Can you guys post some pics of yours so I can get a better idea. Any advice you can offer will be appreciated!
02-25-2011, 01:52 PM | #2 |
Re: Lets see some pics of oversize knobby tires
You might have better luck in the 4x4 section.
02-25-2011, 02:33 PM | #3 |
heres mine, 6" lift with 35" tires and steel wheels, i'd like to go 37's next summer, we'll see. went out playing in the hills
02-25-2011, 04:58 PM | #4 |
I don't consider my set up to be oversize knobby, but it gives you an idea of a 4 inch lift with 33's. And... it fits in my garage (barely) - click on my avatar to pull it up (for some reason I could not cut paste into the thread).
Doug '72 GMC K2500 Suburban 4x4 |
02-25-2011, 05:27 PM | #5 |
Approx 6" lift with Toyo MT's - 315/75/16's (35-ish)
Plenty of room for bigger rubber. Also like K10Dream, plan on going to 37's when these wear down. Doesn't come close to fitting in the garage though.
1968 Chevy C10: 4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc. Last edited by HARJO; 02-25-2011 at 05:28 PM. |
