Old 02-25-2011, 03:38 PM   #1
burkeens
painting full 68 wheel covers
I saw the thread recently about repainting some models of hubcaps. Has anybody here repainted their 67-68 full wheel covers and, if so, can you describe or post photos of what you did? The PO apparently brush re-painted mine at some point, but I would like to do something that passes more than the 10 foot test and I am not an experienced painter. Thanks.
burkeens is offline   Reply With Quote
Old 02-25-2011, 05:21 PM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: painting full 68 wheel covers
Here is what I would do. Since they are chrome or Stainless, I would tape off around the areas that need the color. Scuff up those areas with some scotch bright pads back down to the chrome/stainless. Pull the tape and wash really well with soap and water. Go get a can of Bulldog Adhesion promoter and re-mask the same areas. Spray mist coats of the bulldog 2-3 coats should do the trick. Let 5 min. go by between each coat. Let it dry for about 10 min. Then use some satin/semi-gloss black for the black areas and whatever color for the other areas with the same style of mist coats. Let dry 20 min. and if you want to, apply a clear, if not pull the tape and there ya go. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-27-2011, 01:06 PM   #3
burkeens
Thanks! I will try it that way.
