03-17-2003, 03:02 PM | #1 |
Power Steering Bracket??
My engine is using this block: 14010207 ...350...80-85...2 or 4
and these heads: 3782461....64-66...327......Camel hump,no accessory holes,160/62cc port volumes,62cc chamber. The question I have is what years can I pull a power steering bracket off of. All the ones I have seen involve the alternater on the drivers side and mine is on the passenger side. Also there are no accessory holes on my heads that eliminates a few also. The junk yards here are kinda limited on what they have and I need better info for them to put it out on the wire. My steering box is for power steering but the PO just bridged the two lines on the steering box. |
03-17-2003, 05:30 PM | #2 |
depends on if you are using short or long water pump. if you are using water pump and pulleys that came with that engine then use brakets for p/s pump also.
03-17-2003, 06:32 PM | #3 |
This engine was in the truck when I got it. How do I determine if I have a short or long pump. I can't remember how or what to measure.
Mike |
03-17-2003, 06:56 PM | #4 |
i dont remember the measurments either. ive seen them on here before. im sure someone knows. sorry.
03-17-2003, 09:48 PM | #5 |
Long water pump is 7 1/4 " from fan flange to block mounting flange. Short is 5 something" but this will get you close enough to know which you have.
03-17-2003, 09:57 PM | #6 |
The short pump also doesn't have any mounting flanges on it for accessories.
I got my pump from somewhere in california (been several years ago). It mounts to the block only fairly low on the drivers side. Was fairly easy to get mounted up. I looked all over in yards but they were all gone around here. Could maybe get a pic taken in a few days or something.
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust. |
03-18-2003, 05:17 PM | #7 |
So since I don't know which pump I have can somebody give me a source power steering brackets, for both short and long water pumps, considering the other details(heads and alternator placement). I need to really sort this out I only have a day a week to work on my truck and I hate to waste it digging thru junk yards.
Mike |
03-18-2003, 06:09 PM | #8 | ||
I'm not totally sure of this but I think you will need to use a short water pump if you are planning to use oem brackets. Most of the long pump brackets require the use of accessory holes in the heads. Are you planning to use headers or manifolds and are you going to have AC (if your using exhaust manifolds do they have the accessory provisions for the alt bracket,if headers you'll need aftermarket bracket or adapter). Your best bet is to get a complete set of pulleys and brackets from the same truck. There are a couple of different configurations of the power steering brackets and pulleys used on these trucks. I know from personal experience that the 67-68 power steering brackets wont fit if your using a 8 inch damper. I think the bracket and pulley configurations used on 67-72s is one of the hardest things to get information on. This is a post that appeared on the board about power steering brackets that I saved maybe it will give you something you can use.
72 SWB parts and pieces Oklahoma |
03-18-2003, 08:44 PM | #9 |
drag it like you stole it
i got my brackets from Kenny's Rod shop
do a search and you can find their webpage
negative camber //LA\\ |
03-18-2003, 08:53 PM | #10 |
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
