![]() Join Date: Dec 2006
Changing axles?
I want to convert to truck arm suspension, and I found a rear end to do the swap. It is an early 68 model with 6 lug axles. I have a 71 frame and 5 lug axles, I want to keep the 5 lug can I just swap axles or am I going to run in to problems such as axle length or different spline count?
Grandpa in the rustmobile...
Re: Changing axles?
You CAN do it, but the axles are too long and dont really fit.
They make conversion axles....
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Changing axles?
I agree.
'65-'69 12 bolt=30 1/4", 30 spline '71-'81 12 bolt=31 11/32", 30 spline per Hollander |
![]() Join Date: Dec 2007
Re: Changing axles?
2 options.
Cut off leaf spring saddles off the 5 lug rear end and weld on new trailing arm saddles. Or buy new 5 lug axles for your 68... $250 from Moser. |
Re: Changing axles?
Thanks allot guys, I don't want to cut off the old saddles and weld on new ones if i dont have to. the axle's don't sound bad for 250 though
