Old 05-07-2002, 11:35 AM   #1
worldofme
Post brakes
I have a 77 blazer 4x4 w/ disc brakes and lately when I press on the brake pedal it makes a hissing noise and if I tap the brakes the pedal will go down a little bit on its own. I'm thinking maybe I just need to check the brake fluid level but if that isn't the problem what could be causing this?
worldofme is offline   Reply With Quote
Old 05-07-2002, 10:06 PM   #2
MJN
MJN's Avatar
Post
The gasket between the cover and the master cylinder might have a pin hole in it that is letting air into the system. If that isn't it then the brake lines running from the proportioning valve could be leaking too.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 05-09-2002, 10:38 AM   #3
backyardbuilt
Post
Definitely air in the system just completed changing a bad wheel cylinder in my camaro with the hissing when you pushed the pedal.
79 chevy blazer frame with 79 cab cut down 77 stepside bed 38.5 boggers.
backyardbuilt is offline   Reply With Quote
