02-26-2011, 02:09 AM | #1 |
Blazer tank install without cutting bed brace
has anyone done it..?
I figured I'd ask before I start on this in the spring |
02-26-2011, 09:31 AM | #2 |
Re: Blazer tank install without cutting bed brace
As far as i know, no. All of the pictures i have seen of guys doing this requires a bit of frame modification.
02-26-2011, 11:34 AM | #3 |
I done it once in my old truck, I had to modify the frame and bed brace to get it to fit.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
02-26-2011, 12:20 PM | #4 |
VA72C10
There are other tank options (fuel cell or camaro tank) that work but with the blazer tank, as mentioned, you will either need to cut the cross sill and/or modify the frame
Looking for a 67-72 swb or blazer project in or around VA. |
02-26-2011, 12:39 PM | #5 |
ok. I'll figure something out, as I have the blazer kit, just try'n to figure out why you can't mount it a little lower so not to cut that brace, and with bed of truck under snow and tank kit in garage ,in box..
I'll look and see if I can find good picks of the tank installed with bed off. there must be a way to drop it that inch or two |
02-26-2011, 12:45 PM | #6 |
the only problem that I think it would cause if you drop the tank lower is if your truck is lowered. but other then that I am sure there is a way you can work it out to be lower. if there is a will there is a way.
02-26-2011, 12:47 PM | #7 |
The small cross sill had to come out. Then I drilled two holes in each frame rail and bolted it to the frame. I didn't use the straps, and I had to make 1 inch spacers from square tubing to get the tank low enough to work with my filler neck.
1969 C-10 short step 1981 CJ7 2017 Ram 2500 Laramie 4X4 1939 Cadillac LaSalle sedan 1950 Allis Chalmers B 1998 Bullet 21 XD 300 Merc/water hot rod |
02-26-2011, 01:29 PM | #8 |
thanks,, looks good,
02-26-2011, 01:30 PM | #9 |
Thanks. It was well worth the effort.
