Old 02-26-2011, 11:02 AM   #1
Restrorob
The One And Only !!!
Restrorob's Avatar
Electric Fan Guy's Step Inside Please >>>>
I'm doing the Jeep fan install on my rig, I have a box of relays/connectors/terminals and rolls of wire from my line of business. I hate to spend as much for a relay kit as I did for the fan from moparparts, I'd rather custom tailor a harness to my needs.
I need a line on a 3/8" pipe thread sensor with on at 185 off at 170 (unless someone has a better temp range).
Maybe a year and model vehicle or a brand and part number for the application, I checked at my local NAPA and the "girl" flipped through a book for half a minute then said they had nothing.
I'd rather buy local if possible so if I did have a issue I wouldn't be down for a week or more waiting for that big brown truck....
Thanks for any help !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-26-2011, 02:10 PM   #2
Red_69
Red_69's Avatar
Re: Electric Fan Guy's Step Inside Please >>>>
Have you looked into the universal fan wiring kits from jegs or summit?
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 02-26-2011, 02:13 PM   #3
Red_69
Red_69's Avatar
http://www.summitracing.com/search/?...ng%20kit&dds=1
Pretty reasonable and adjustable too.
Old 02-26-2011, 02:23 PM   #4
pig rig
pig rig's Avatar
you can look up parts spec. and numbers on napa's online catalog and then you compare parts and it will give you data on the parts
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-26-2011, 02:24 PM   #5
Restrorob
Restrorob's Avatar
Thanks for your reply Red 69, But I rather just buy a sensor and as below;
Thanks pigrig, I'll check into that !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-26-2011, 02:47 PM   #6
tim660cc
tim660cc's Avatar
I got mine at the local rice tuner performance store, however it was 195 on 180 off, little bit hotter than you want. It was 20 bucks.
tim660cc is offline   Reply With Quote
