Old 02-26-2011, 02:09 PM   #1
revjim
Distributor removal...UGHH
I am restoring the engine while in the engine bay...Nothing fancy, but I wanted to remove the distributor. HOWEVER, it continue to hit the firewall. What now? ALSO, is there a distributor that people are using over others? MY engine is a 350 LM1 crated chevy. Thanks for the help..
revjim is offline   Reply With Quote
Old 02-26-2011, 03:37 PM   #2
glendale
glendale's Avatar
Re: Distributor removal...UGHH
did you pull the cap? rock it toward the front end it should come out.
glendale is offline   Reply With Quote
Old 02-26-2011, 05:04 PM   #3
jocko
jocko's Avatar
i'm a little confused (nothing new) - since it is a crate motor, is it perhaps an HEI?
I'm assuming not since you are restoring, so if not, then I believe what glendale mentions is best approach - remove rear mounts and tilt rear of engine/trans up to lean the distrib/eng combo forward a bit. If it's an HEI, not sure if that will be enough clearance, but if it's a stock points-type or at least points size cap, then you that should give you enough room. Be carefull when you move everything back (i.e. after the distrib is back in) to not tilt the engine too far back in the original direction or you can crack the distrib (or worse yet the manifild) by smacking the rearward facing portion of the distrib cap on the firewall. Cap would probably crack first, but either way it ruins one's day...
Old 02-26-2011, 05:43 PM   #4
revjim
No...it is a crate motor. But doing clean up and detailing and I want to get to back of motor. Very frustrating.
Old 02-27-2011, 01:47 AM   #5
Rich 5150 69
Rich 5150 69's Avatar
All those that are using the crossmember/engine mount rear holes with HEI will have dist/fire wall clearance issues, most will fit but you will have to remove cap first then distributor, same for reinstall, that is how mine is, although we have had a few here that said they never could get theirs to fit...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
