Old 02-26-2011, 02:12 PM   #1
Tuff Gong
Tuff Gong's Avatar
1968 LB - 2 piece drive shaft question
I'm headed to the junk yard for a driveshaft for a 1968 LB. Are the 2 piece drive shafts interchangeable for 67-72? Or can I only pull it out of a 68? Thanks.
Tuff Gong is offline   Reply With Quote
Old 02-26-2011, 02:15 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 1968 LB - 2 piece drive shaft question
Should make sure of your trans and rear end also. You need to match those up.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-26-2011, 02:25 PM   #3
Tuff Gong
Tuff Gong's Avatar
OK, so the trans, rear end and year need to match up? Is this correct?
Old 02-26-2011, 02:28 PM   #4
Tuff Gong
Tuff Gong's Avatar
The SPID reads
m35 powerglide trans
g50 HD rear spring
Old 02-26-2011, 03:17 PM   #5
mr48chev
mr48chev's Avatar
Yep, the back half should be the same length for long wheelbase trucks but the front half has to match the transmission you have.
I can't remember if the different rear ends take different U joints or not but that could be an issue.
If this pfd works it should give you the measurements for your transmission and you can see that it is within a few 16ths of a short shaft turbo 350 in length but you may have to swap front yokes to match the powerglide.
Old 02-26-2011, 03:18 PM   #6
dmack91
dmack91's Avatar
I think what they are referring to is that the connections need to match.
If you have the output shaft with yoke on the trans you are using, you need to make sure the driveline you find has the same U-joint size to match up with the output shaft. Same on the rear end - u-joint has to be the same size on the rear of the driveshaft and the rear-end. Overall length should also be confirmed.
If you don't have the output shaft with driveline yoke on the trans, you will have to make sure your donor will mate up with the trans output splines and diameter.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
