Old 02-26-2011, 04:32 PM   #1
ItsRandy
ItsRandy's Avatar
Pinion angle\2 piece driveline question
I'm getting ready to set the pinion angel on my coil spring 69 1\2 ton long bed. I have information that you set the pinion angle just as you would if you were working on a single piece driveline (pinion 3* above horizontal, crank\out put shaft 3* below horizontal)...does anyone know, is this true? Location of the carrier bearing doesn't come into play?
ItsRandy is offline   Reply With Quote
Old 02-26-2011, 08:54 PM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Pinion angle\2 piece driveline question
I know that's right for a single shaft. You might want to mock it up, and see how it looks, and go from there. Good luck.
bigsnookmaster is offline   Reply With Quote
Old 02-26-2011, 09:16 PM   #3
crazy longhorn
Fabricate till you "puke"
The way it was explained to me, by a local driveline shop is thus....the front have of the shaft needs to be pretty much veiwed as an extension of the trans. The 1st U joint needs to have a 1/2 -1 degree working angle, & the last 2 joints are set up equal/opposite of each other. You wont get too much movement on a coil set (wrap up), but on a leaf spring truck, the springs wrap quite a bit, & do change the pinion angles on hard acceleration. what I have seen done on leaf setups for high perf /drag (1 pc shaft), is to set both angles 3 degrees down toward to ground. it will run smooth this way, & under full power, it will kick the pinion up around 6 degrees(still running 3 degrees on both ends). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-27-2011, 03:02 AM   #4
leddzepp
Moderator
leddzepp's Avatar
How much have you lowered the truck from factory? I have a 5/6.5" drop on my SWB, with the factory 2 piece driveshaft. I did not need to correct the pinion angle, and no shims were needed.
Moved to suspension forum.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-28-2011, 12:25 AM   #5
ItsRandy
ItsRandy's Avatar
4\6 but installing 9" ford, I want to get it right.
Old 02-28-2011, 02:43 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Here is a thread with some very helpful info: http://67-72chevytrucks.com/vboard/s...d.php?t=397394
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-28-2011, 02:45 PM   #7
fixit-p
fixit-p's Avatar
crazy longhorn is correct in that you want to set up the first u-joint to have ~1* true operating angle and the pinion centerline needs to be parallel with the centerline of drive shaft #1 and not the transmission. here are a couple more threads that address 2 piece drive lines. http://67-72chevytrucks.com/vboard/s...d.php?t=220466 http://67-72chevytrucks.com/vboard/s...d.php?t=405802
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 03-01-2011, 12:30 AM   #8
ItsRandy
ItsRandy's Avatar
Wow! Thanks for the information. Sounds like you have set-up a drive-line or two...or you are just REALLY smart! Thanks again.
Old 03-01-2011, 12:43 PM   #9
fixit-p
fixit-p's Avatar
Nope, I just stayed at a Holiday Inn Express
