Old 02-26-2011, 06:12 PM   #1
lha1992
lha1992's Avatar
Type of cam in stock '89 chevy 350 motor?
I was just wondering of type of cam that is in my 1989 chevy silverado 1/2ton? Its a 350 K-code motor, all stock, nothing has ever been done to the motor. Same motor since it was new.
Is it a roller cam, flat-tappet, etc? I'm just wondering is all. Thinking of later on down the road of what updates I could do to the motor.
lha1992 is offline   Reply With Quote
Old 02-26-2011, 06:27 PM   #2
bwood
bwood's Avatar
Re: Type of cam in stock '89 chevy 350 motor?
It should be a hydraulic flat tappet cam. The block is roller cam capable, but you need the cam and lifters of course, but you also need the 8 lifter plates, 1 lifter plate retainer, 1 cam plate and the bolts for them all.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 02-26-2011, 08:09 PM   #3
lha1992
lha1992's Avatar
So it is a hydraullic flat-tappet cam? Does that mean also that I need to run oil that has enough zinc or ZDDP in it or does that only apply to the older trucks from the 60s and 70s?
And thats good its roller cam capable. So I could go with some Comp Cam if I wanted to right? But then that brings up the TBI which i've heard does not like big cams.
Old 02-27-2011, 01:03 AM   #4
89chevsj
error 404
89chevsj's Avatar
tbi doesnt like BIG cams but you can put a bigger cam in it. yes it can be expensive but it really makes an improvement. especially if your trying to builld a sleeper outta "PAW PAWS truck"
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 02-27-2011, 02:25 AM   #5
lha1992
lha1992's Avatar
Yeah, thats what I thought after reading all the threads here haha. But yeah, i'm just getting ideas for later down the road for Paw Paws truck. As you said, i'm thinking of makin a sleeper out of it. Looks stock but has something hiding underneath the hood
Other than the worn valve guides where it will give the chevy salute when it hasn't been started up in a few days the engine runs great! As ya'll say, drive it, take care of it and when something breaks fix it.
Old 02-27-2011, 05:17 PM   #6
89chevsj
error 404
89chevsj's Avatar
I'm sure someone will tell you the specs for camming it. i always liked sleepers haha. is why i always buy them. i would start out with a new exhaust (duals) headers and see where that will get ya.
'12 Kia optima
Old 02-28-2011, 06:52 PM   #7
Orangette
88-95 trucks came with Flat-Tappet cams, SOMETIMES the block is roller capable, but not ALWAYS.
96+ Got roller cams.
TBI does not like big cams, if your thinking your gonna get a low LSA cam with a rough idle to run proper in a TBI 350, forget it.
Josh
1978 RCLB K20, Built 400 SBC, SM465, Lifted
1994 RCSB Silverado, 375HP 350, TH350, 4/6, Toy
Orangette is offline   Reply With Quote
Old 03-01-2011, 11:10 PM   #8
89chevsj
error 404
89chevsj's Avatar
guess i got lucky. of course mine is a very strange set up thatI dont even know everything about yet.
'12 Kia optima
Old 06-25-2012, 11:57 PM   #9
motovate
I know this is an OLD thread - but maybe some one who knows can give me an answer. I understand TBI engines don't like bigger cams - but is it the TBI itself not the engine itself?? In other words if I take a running TBI engine in a 1989 Chevy Suburban- pull the TBI, manifold, distributer, cam and do away with the computerthen replace with an Edelbrock Performer carb, manifold, cam, external wired fuel pump and HEI dist will it run like an non TBI engine????
It would seem it should.
Thanks.
LBM
motovate is offline   Reply With Quote
Old 06-26-2012, 07:46 AM   #10
BigBlocksRule
TBI computers are vacuum sensitive, so a cam with much less lobe separation angle won't work well with the computer. The '96 up multiport injection can handle a lot more since it measures engine load and airflow differently.
The block itself is capable of a good bit more power than the TBI can provide.
BigBlocksRule is offline   Reply With Quote
Old 07-04-2012, 05:38 PM   #11
motovate
Cool Re: Type of cam in stock '89 chevy 350 motor?
Thanks - that makes sense.
LBM
