Old 02-26-2011, 11:30 PM   #1
samstheman
Exclamation 1977 thermostat housing inline 6 250
Looking for a thermostat housing the one that bolts to front of motor. For a 1977 chevy 250 inline 6 cant seem to locate one Mine has small hole .
samstheman is offline   Reply With Quote
Old 02-27-2011, 12:24 AM   #2
Telecasterjoey
Re: 1977 thermostat housing inline 6 250
I know lmc has them, but a cheaper alternative would be the junk yard.
Telecasterjoey is offline   Reply With Quote
Old 02-27-2011, 09:13 AM   #3
tucsonjwt
Available at NAPA, Rock Auto, etc. - should not be hard to get. I would stay away from used part due to possible pinhole issue just like you have.
tucsonjwt is offline   Reply With Quote
Old 02-27-2011, 09:08 PM   #4
SeanPaintsFlames
SeanPaintsFlames's Avatar
The aluminum top part, or the cast lower section?
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 02-28-2011, 01:17 PM   #5
samstheman
The bottom part the junk yards have been picked Ill try LMC
Any other source would be appreciated. Thanks
Old 02-28-2011, 01:48 PM   #6
geezer#199
Is this what you are looking for? I picked up an operational 250 from a 1980 Chev short box for the oil pan.
Jack
geezer#199 is offline   Reply With Quote
Old 02-28-2011, 02:13 PM   #7
geezer#199
Here are some better pics
Jack
Old 03-01-2011, 06:29 PM   #8
samstheman
My plugs are a little differnent one up top and one on lower unit But Ill check a little cl;oser maybe it will bolt up Thanks Ill get back to you
Old 03-02-2011, 01:06 AM   #9
samstheman
Here is mine it looks real close will yours work do you know?
Old 03-02-2011, 01:13 AM   #10
geezer#199
I pm'd you.
let me know.
Jack
Old 03-02-2011, 01:21 AM   #11
samstheman
Thanks for your offer
Old 04-06-2011, 03:15 PM   #12
68 IRON
68 IRON's Avatar
Found this on another site: http://www.oehq.com/oeparts_ACD15-80766_ACD.htm
I'm planning on putting an electric fan on my 68 and wanted to put the temp switch on the thermostat housing....hope you found one!
68 IRON is offline   Reply With Quote
Old 12-13-2011, 04:27 PM   #13
Green 1959
Green 1959's Avatar
Where did you wind up finding one? I am having the same problem, mine is out of a 82-84 i believe, looks like greezer's only with 2 ports on the drivers side.
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 12-19-2011, 01:30 AM   #14
samstheman
on ebay a nova 6 cylinder same one
Old 12-20-2011, 12:40 AM   #15
Green 1959
Green 1959's Avatar
I didn't find it, what key words do I need to use?
Old 12-21-2011, 01:00 AM   #16
samstheman
It was a used one not new just happen to find it
its a thermostat housing inline 6
Old 12-22-2011, 08:36 AM   #17
Green 1959
Green 1959's Avatar
I still can not find it, do you have the item number?
Old 12-26-2011, 03:44 AM   #18
70c-10
there are lots of different housings out there. I've seen them with one, two, or three holes on the drivers side. The angles of the outlet for the heater hose also varies.
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 12-26-2011, 11:38 AM   #19
Green 1959
Green 1959's Avatar
I need the lower housing. I did find one on ebay but biding is almost to 50 dollars
Old 12-07-2015, 09:13 AM   #20
jturner18
I'm in search of a 68 model 250 water housing. Anyone with any info without giving up my mortgage for one. Lol
jturner18 is offline   Reply With Quote
Old 12-07-2015, 12:10 PM   #21
truckin 79
I didn't relize these were in such high demand. There are 3 inline 6 trucks at my local junkyard, one is a 73 GMC a 75chevy and I think the other is a 80. If you are in anywhere near northern CO come take a look. I might be able to convince my wife to let me go next weekend and could try and pick those up for you. Anything else on inline 6ers worth picking up
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 12-07-2015, 12:30 PM   #22
walkerb
walkerb's Avatar
I need a original oil cap for the valve cover on a 74
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
