driveshaft clearance on 12 inch lift
how would i go about getting the front driveshaft to work on a 84 k10 longbed with 10-12 inch suspension lift? pictures would be great.
thanks. |
#2 | |
Re: driveshaft clearance on 12 inch lift
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
toys'r'us
look into a divorced transfercase
Chevys Kick A$$
Can you drop the transfer case down to help out at all? I know its possible to crank the front axles upwards at a better angle think that takes a lot of work though lol!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
toys'r'us
do a 1' body lift
Getcha Pull
I agree with LONGHAIR. Contact High-Angle, or Tom Woods. See what they say about what you need. They might be able to put you together a CV shaft that will get you by. Maybe a slight clock of the transfer case combined with the new shaft would be the best middle ground before getting into extreme mods.
Extreme being turning the C's on your front axle to set the pinion angle without effecting your chamber, and steering.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
800$ starting price for a front driveline to work with that lift.
nickle and dime |
