Old 02-27-2011, 01:08 PM   #1
dmack91
dmack91's Avatar
Fuel Sender Question
OK, so I got my new sending unit from Classic Parts and see that it has a different connection than my old one. The new wire connnector looks like it takes a connector that slips over and snaps into place (no threads). My old one was a threaded stud that a ring terminal connected to.
Not sure if I have enough room at the base where it is threaded to the base with a nut to put my ring terminal under or not, and I haven't seen the slip-over connection for sale before.
Any idea where I would find the newer connector (NAPA maybe)?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 02-27-2011, 03:49 PM   #2
treveiger
treveiger's Avatar
Re: Fuel Sender Question
Mine has a slip connector that just slips on and snaps into place at the fuel sending unit. My truck is a 69. Did the older units for these trucks have a different connector than what the later trucks do?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 02-27-2011, 04:17 PM   #3
dmack91
dmack91's Avatar
Not sure. Mine is a threaded stud that comes out of the sender for the wire to connect to.
Old 02-27-2011, 06:55 PM   #4
treveiger
treveiger's Avatar
Ill check LMC tonight and look around to see if there different for certain years, trucks get changed and modded throughout the years which can end up sucking to find the part needed, maybe call up Classic Parts and tell them what you need and see if you can exchange it. Im suprised nobody else has chimed in yet.
Old 02-27-2011, 07:50 PM   #5
dmack91
dmack91's Avatar
Thanks for the help.
When I pulled the old unit, I found that someone had scabbed in a universal sender with a mess of tubing, coat hanger, etc. attached in an attempt to make it fit.
Installed the new unit and NAPA had a connector that was close enough that I was able to make it work.
Thanks again.
Old 03-01-2011, 09:59 PM   #6
treveiger
treveiger's Avatar
Glad to hear its working again. Sorry it took me so long to get back on, been busy with work. I wonder if its not a fuel sending unit for a 60-66 chevy truck because they have the ring terminal. This is what a 67-72 fuel sender should look like http://www.carpartsdiscount.com/auto...html?3593=2631. Doesnt show a decent picture of the top though.
Old 03-01-2011, 10:42 PM   #7
timzrides
timzrides's Avatar
Same problem, i bought a new blazer tank from classic industries, it looks like a slip on also but the wire i robbed from a 68 had a ring with a nut? Confused also.
timzrides is offline   Reply With Quote
Old 03-01-2011, 11:44 PM   #8
dmack91
dmack91's Avatar
NAPA had a terminal that was a bit small, but with some massaging from an awl, and it worked fine.
Old 03-02-2011, 12:55 AM   #9
Clutch442
Clutch442's Avatar
My 71 has the snap on connector if this helps at all. Just changed out the original sender, the wire has not been changed.
Clutch442 is offline   Reply With Quote
