Old 02-27-2011, 02:44 PM   #1
bsteele
307 ?
I removed the tired old 307 from my 69 the other night and have the rebuilt 350 ready to put in. My question is does the 307 and the 327 have the same crank? I have had several people tell me they want the 307 for the crank. If this is the case I might just sit on it a while instead of selling or giving away.
bsteele is offline   Reply With Quote
Old 02-27-2011, 09:22 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 307 ?
The 307 crank is shorter stroke than a 350 crank.
Last year I used a 307 crank in a 350 block which made a nice 4 bolt main 327 engine. I have already gotten another 307 crank on the shelf in my shop waiting for the next engine I build.
Old 02-27-2011, 09:29 PM   #3
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: 307 ?
TX - what rods and pistons did you go with?
screamin_c10 is offline   Reply With Quote
Old 02-27-2011, 09:47 PM   #4
Tx Firefighter
Re: 307 ?
Cheap Scat rods and Hyperutectic 327 (4.030 bore) pistons from Summit.
Old 02-28-2011, 01:25 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: 307 ?
You can use the 307 crank AND RODS in the 350 block to make a 327.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-28-2011, 04:40 PM   #6
MARKDTN
Re: 307 ?
Yes, a 307 and 327 crank are the same. (all 307 are large journal, while 327 is small journal except 1968 and heavy truck) The internal balance is a bit different, but if you have it balanced it will be fine. Kinda the same thing with a 305 and a 350. Same stroke, but mixed results if you don't rebalance the assembly.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
