02-27-2011, 03:27 PM | #1 |
Gears
How do I identify A posi carrier? The only stamp I see on it is 30060, ED01, 138 and armasteel. These are the only markings I see.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
02-27-2011, 03:50 PM | #2 |
Re: Gears
I never go by the code on rear ends,good chance they have been redone or swapped out for something else.I take the cover off and look for the gear ratio while there then you know what it is.You can get the backend up off the ground and then spin 1 wheel and c if the other wheel is going in the same direction,but I still take the cover off
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-27-2011, 04:07 PM | #3 |
Re: Gears
These are the stamps on the carrier itself.
02-27-2011, 05:38 PM | #4 |
Spanked once
Re: Gears
I'll let you open this link if you tell me how wide your tubs are and why you used four new ones.
http://www.chevelles.com/forums/showthread.php?t=58478
The ole 350 budget build. |
02-28-2011, 04:17 PM | #5 |
Re: Gears
Thank You for the link. Good info. My tubs are 17" wide not including the mount flange. I used 2 to make 1.
02-28-2011, 04:49 PM | #6 |
Spanked once
Re: Gears
The reason I ask was do the re-pops not match the good enough or were your original ones to messed up? And thanks for the measurement.
The ole 350 budget build. Last edited by Richard H.; 02-28-2011 at 04:54 PM. Reason: . |
02-28-2011, 04:54 PM | #7 |
Re: Gears
I sold my old bed complete steel floor shortbed including the blaser tank and filler I built. The new fenders were fine I just grafted 2 together to get the width.
