![]() Join Date: Feb 2011
C-10 Air bag questions!!! HELP!!!!
I'm interested in getting the Ride Tech Level 1 Air ride Technology kit. I want to go simple and cost efficent. With the options to upgrade. No C-Notch and no fabs to the bed and inner fenders. I want to go with 22"s.They advertise that it's possible. is this true. Any suggestion on installation and switching out the front springs. I heard that it's very dangerous. Here's the kit I want to get ...
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: C-10 Air bag questions!!! HELP!!!!
Orange, gunna move you to the suspension gurus
Thanks, I really need the help. I'm new to the sight so I'm still learning my way around!!!
Posted via Mobile Device |
![]() Join Date: Feb 2008
You can do it but how low you trying to go. 22"s are big, so your gonna be way up off the ground.
Im going with 20s and Ill be layed out with a Porterbuilt Set up....but that's no fenderwells. |
2.5 in the front with 4 in the back for driving. I want to keep my fenders in tack. I heard that the airbags is a much better drive. I'm not trying to slam it.
Happy to be here
![]() Join Date: Mar 2000
If thats all you are after, I would just do a static drop.
67-72 parts collector,…
![]() Join Date: Nov 2002
No air ride.
Just a set of drop sprindles and springs. Tell us more about your truck. What year? What mods have been done already? Got any pics? Budget? A static drop can be very fun to drive. Add sway bars if you don't already have them.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-27-2011 at 07:05 PM. |
#9 | |
http://67-72chevytrucks.com/vboard/s...ht=Urban+Retro |
If you are considering installing air bags,... I wouldn't buy any wheels until the bags are installed so you can measure for proper clearances.
The RideTech kit is a quality product. We have several board supporting vendors that sell RideTech kits. Check out the Suspension Marketplace.
#11 | |
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
Happy to be here
It really depends on what height tire you want on the wheel, and how low you want to go. I understand that you don't want to cut your bed or inner fenders. With those limitations combined with a tall tire, you might not need the air suspension.
If you plan 22's or 20/22's low profile tires, the air suspension system you have pictured would be a nice addition.
#13 | |
#14 |
22x8.5 up front and 22x10 in back would be the max.
I like a 40 series tire. 265/40 and 285/40 with those rim sizes. Some people run a 35 series tire to keep down on the overall tire height.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-27-2011 at 08:35 PM. |
#15 | |
#16 |
A fellow Owasso board member here, I've got a 69' with 5 lug disk brake conversion, 2.5"/4" drop. Drop spindles with stock springs in front and 4" springs in rear running 20" wheels (I will have to check tire size). My tires rub the front inner fenders only in extreme situations. I think lower profile or a better offset could help. A little different set up than yours but close to what your trying to achieve.
1969 C-10 CST SWB 350/350 1967 Camaro RS 327/PG |
#17 |
Happy to be here
I agree that a 40 series is much better for ride, and I like the looks too. Orangetonicclicc while researching the difference between 35 and 40 series tires try to look at pics or the actual tire to get an idea. What I have found is that all tires are not true to their listed size. If you compare several 35 series tires, in the same sizes, the sidewall can be significantly different from one to another.
#18 | |
#19 | |
#20 |
![]() ![]() Posted via Mobile Device Posted via Mobile Device
--soon to be Simply Bluetiful '67 SWB-- http://67-72chevytrucks.com/vboard/s...ar#post4534028 |
#21 |
The series sidewall is related to the width of the tire. That 35 or 40 is a percentage of the width, so a 285/40 will have a taller sidewall than a 255/40.
The 40's series are tall tires and great for a mild drop. They could rub if going up a driveway turning where the suspension flexes, but in general they should be Ok if you're not too low. The backspacing (offset) of the wheels also make a difference. To not over complicate it, the 40 series, I think would be good for the drop you mentioned. Although might rub occasionally in certain situations, for everyday driving, it would be Ok. |
#22 |
I really appreciate the info,thanks!!!
