Old 02-27-2011, 08:12 PM   #1
sider68
sider68's Avatar
Steering / Brake Help Please
I,m trying to get some answers for my steering and brake questions and I know the 67 to 2 guys/girls know just about everything .
I have 4 wheel standard drum brakes and manual steering.
I would like to make both power. Whast parts do i need? Can they be obtained at a local jobber?
My wheels are 6 bolt and i,d like to keep them that way so i dont have to buy new ones so no switching to 5 bolt discs. I,ve heard that drums can even be drilled for venting. I just want to drive truck as recreation so i wont be putting a ton of miles on it.
These are the last fixes I have to get doneto get this put back on the road which i would really like to do this year. Please help.
sider68 is offline   Reply With Quote
Old 02-27-2011, 08:49 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Steering / Brake Help Please
Hmmm, if I recall..
Brakes will need a master cyl/booster, brake fluid,
vacuum line for the booster, and a place to plug it in (usually a ‘T’ fitting
on the back of your intake)…some if not all available from local parts store.
Power steering gets a power steering box, pump, pulleys & belts, brackets
to hang the pump on, etc. Brackets & pulleys at the pull-a-part (take pics
of the donor truck’s set up). The rest you can buy new or reman.
I think on some early 68’s you may not have a dimpled frame for the
steering box. We used to beat it in with a sledge but I’m sure someone
here has a better way.
Any corrections or missing things here gents?
ETsC10 is offline   Reply With Quote
Old 02-27-2011, 09:02 PM   #3
Kidd-7
Kidd-7's Avatar
Here is a link to a booster/MS/ mounting bracket from summit. Looks like good deal.
http://www.summitracing.com/parts/AAZ-50-1125/
Kidd-7 is offline   Reply With Quote
Old 02-27-2011, 09:10 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
ET only left out one thing I can think of..Make absolutely sure to get ALL of the pulleys from the donor!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-27-2011, 09:23 PM   #5
glider_6969
I just did what you are looking to do.Here are some pics of parts I used., some brackets I had to make, to hard to find or they wanted way to much money for them. We on this side of the boarder have more trouble finding goods parts. If you need more help don't be shy. There are lots of pics on this board.
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline   Reply With Quote
Old 02-27-2011, 10:15 PM   #6
cdowns
cdowns's Avatar
drum brakes dont have or need proportioning valves they use distribution block and you should already have one in place.
bad idea to drill drums for venting as it can cause weakness and failure of the drum
Old 02-27-2011, 10:26 PM   #7
ETsC10
Hand Crafted C-10
ETsC10's Avatar
You are absolutely correct...was thinking on what I had changed
on one of my trucks and forgot the prop valve was due to the
disc brakes...my goob. Thank you.
Old 02-27-2011, 10:28 PM   #8
dmack91
dmack91's Avatar
To convert to power brakes, all you need is to find a donor truck with a power brake booster setup. Get all of the parts from the pedal linkage (rod that bolts to the pedal) through the booster. It is a direct bolt on. I did mine in about an hour. Even the stock lines are long enough, just bend them slowly and evenly.
There was a step by step tutorial on here somewhere.
Best mod I have done. I did a full brake job, but it still took a lot of effort (been a long time since I had a rig with manual brakes, so I couldn't remember how much effort was normal). Before I definitely had to plan ahead when coming to a stop. Now it is just like all of the cars you are used to driving with power brakes.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
