number 1
When did the factory start stamping the vin # on the FRAME of chevy and GMC trucks ?
its all about the +6 inches
68 I do believe.
![]() Join Date: Mar 2003
Where on the frame rail is it? I have no numbers on the truck I am restoring.
It depends on which year your truck is?
The 68 through 72 is near the steering box. But they are all a little different. Have fun
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
this is one spot or very close..... scrape around on the top of frame. You will only have the last 7 or eight numbers there because they number before that would be the same on most trucks of the same model number. These are the specific sequence number which match the sequence number of your vin and usually the first number or letter is the year of frame. Example a Z meaning 70 or 9 meaning 69.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Almost Satisfied
![]() Join Date: Mar 2002
Mine is stamped by the power steering box and on the top of the frame rail under the cab, left side.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
i ran into the same problem on a 67 gmc i just picked up. looked for vin on frame rail by steering box but there isnt 1 there. havent checked rest of frame yet.
Life is Good !
I bought a 67 4X4 and they put the #s on that truck at the factory. One set under the cab and one set in the engine compartment right where ROD was pointing. So I would have to say they started in late 67.
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
NUMBERS GAME
I have found VIN numbers on my 67 C20 in 2 places on the left side of the frame but I remember Dessert Rat saying he had a 67 GMC frame with no frame numbers at all and it was factory . I have also read some posts in the 60 -66 truck forum and it seams like some of those trucks might have had frame numbers ?????
landon...actually, that's me pointing!
![]() Something interesting, the numbers don't always match up perfectly. The number on the frame of the Longhorn is one digit off from the vin/title. |
