Old 02-27-2011, 11:50 PM   #1
madchopper
Seperntine Belt Kit
I just recently bought a serpentine belt kit for my 67 GMC pickup and none of the bolt holes in the brackets for the A/C and alt have been drilled in my heads. I am very lery of drilling and tapping them out. Would the four bolts that hold the two brackets in the Water pump be sufficent. I looked at this post in the FAQ's but only found one post about tapping a drilling one bolt hole. Any suggestion here would be great.
madchopper is offline   Reply With Quote
Old 02-28-2011, 10:44 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Seperntine Belt Kit
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-28-2011, 11:38 AM   #3
Lee H
Lee H's Avatar
I would not drill the heads. To much can go wrong from mis alignment, punch through, cracking, etc. Also the heads with factory holes have bosses so you would have to make shims for proper alignment. Would be easy and fairly inexpensive to do a head swap. You should be able to get a set of ready to bolt on heads from your local machine shop for a few hundred dollars.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-28-2011, 02:54 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I've seen serp setups that just bolt to the waterpump bolts.
do not drill and tap your heads!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-28-2011, 03:51 PM   #5
madchopper
The kit did come with some bracket from GM that go down and attached to the end of the header bolts, so it is not just bolts near the water pump. These brackets seem to give it more stablity. I was thinking of making a braket that would use the current bolt hole locations and would tie the two bracket together over the water pump. Think that is nessacary? Thanks for the info guys.
Burdic what is TTT?
Old 02-28-2011, 04:40 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
no wories madchopper....ttt= to the top....we also use "bump".....it brings your thread back to the top of the forum so those that missed it will see it and it gets more exposure so you'll get an answer to your question
and by the way... to the boards from NC.....
Geoff with a G
Old 02-28-2011, 05:16 PM   #7
firedog
firedog's Avatar
so i am understanding you bought an aftermarket serp kit? There are a couple different factory designs available on v8 and v6 built in the 90s. My factory serp kit bolts to the heads also but i think there are others that bolt into the block and use the water pump bolts too
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-28-2011, 05:38 PM   #8
madchopper
I bought the kit From Jeg's and the bottom of the brackets bolt below the water pump not using the waterpump holes, mis spoke when I typed it up. I forgot i dont really want to swap the heads since I just had them polished an ported when doing a rebuild, maybe in a few years.
Thanks burdic
Old 02-28-2011, 09:11 PM   #9
BOZO
Old School
BOZO's Avatar
I installed a serpentine setup from a 1999 4.3 liter V6 Chevy truck onto my Gen 1 small block with minimum modifications. The installation included a high amp alternator,air conditioning compressor, PS pump and the V6 water pump. To use the reverse rotation water pump, I had to drill out the bottom passenger side bypass hole and tap it to put in a 1/4 pipe plug. This was a very cheap upgrade for me as I already had the wrecked 99 Chevy. Attached are a few pictures of the installation. You can use the passenger side bracket as a template to find where the extra hole gets tapped.Your brackets may be a little different but they all bolt up in the same place. When drilling the passenger side head, just make sure you barely miss the intake manifold bolt hole. Make sure the tapped hole is on a flat bossed surface.The passenger side bracket has 3 mounting holes in it, but you can get by with 2.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
