02-28-2011, 03:24 AM | #1 |
question!
hi gents
i have a 1972 sierra grande with VIN: TCE242F711366 i cannot finde any web site shows me the factory options can anybody help me with that thanx |
02-28-2011, 04:49 AM | #2 |
Re: question!
Your vin won't show options. See if you have a SPID (Service Parts IDentification) sticker on the inside of the glovebox door. That will show your options. A buildsheet will also show options. It's a piece of paper found in the truck somewhere. Most buildsheets are long gone, but sometimes you can still find it under or behind the seat between the foam and the springs. If you have either here is a decoder for the options. http://outintheshop.com/options.html
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 02-28-2011 at 04:50 AM. Reason: spelling |
02-28-2011, 07:58 AM | #3 |
Re: question!
you are right i check SPID and its ok. but one of my friends says that 1972 engine never comes with 402 cu. in.
and just i want hem to see the engine size from the VIN. thanx bruceman |
02-28-2011, 02:08 PM | #4 |
Re: question!
Hello gm 187, I can happily decode your vin for you but it won't show the size of your motor. Only if it's a v8, v6, or i6.
T=GMC C=2 wheel drive E=V8 2=3/4 ton 4=pickup 2=1972 F=Flint Michigan assy. plant 7 is a place marker 11366=number produced So the vin tells you that your GMC came with a V8 but not what size. 402 was the only big block V8 for the 1972 trucks and it did come in 1972 GMC trucks. 1968 and 1969 trucks had 396 V8s. In 1970 the 396 went to 402 and they called it a 400(I don't know why) 1970 thru 1972 trucks had 402ci for the big block. The 402 big block was a option so it should be listed on your SPID. If so you can show your friend that the 402 came with your truck from the SPID but not the VIN. Hope this helps
CHEVY/GMC VIN DECODERS |
02-28-2011, 02:12 PM | #5 |
Re: question!
Part of the VIN will be samped in the front of the engine if it is original. If it isn't original you can decode as to what it originally did come in.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-28-2011, 02:42 PM | #6 |
Re: question!
Sorry to disagree but for our trucks no part of the vin is anywhere on the block. In passenger cars it was but not the trucks. There is a code on the block that will match the protect-o-plate and it tells where built, when built, and for what type of truck. But for our trucks you can't prove the engine by the vin. You can't prove the engine is original numbers matching at all, but you can remove most doubt by that date code on the front passerger side block.
02-28-2011, 03:04 PM | #7 |
Re: question!
will guys thanx for that info. but in the SPID the engine is 400 how come
:S Posted via Mobile Device |
02-28-2011, 03:10 PM | #8 |
4wd Enthusiast
Re: question!
The 402 engine was listed as a 400 ci v-8 engine on the SPID in 72
*1972 Cheyenne Super SWB K10 Original Paint 350/350 AC (Added) Tach/Tilt *1972 Cheyenne Super SWB K10-Buckets/Tach/Tilt/Wood Bed/Manual Throttle/Marker Lamps *1972 Cheyenne Super Custom Camper K20 AC/Tilt/Aux Tank/Aux Battery/Wood Bed *1970 Olds 442 W-30 M-21 4-speed *1978 Ford F250 4x4 Ranger-Explorer-Camper Special Marti Report: 1 of 1 *1986 K30 Silverado Crew Cab 502/TH400 *2002 Silverado LT 2500 Duramax Long bed Crew Cab 4x4 107K original miles *2022 RAM Bighorn 1500 Waldoch edition ...Daily Driver |
02-28-2011, 05:24 PM | #9 |
its all about the +6 inches
Re: question!
This is true. It was called a 400, but it was in fact a 402. This is in fact the ONLY big block offered in a 72 pick up.
