Old 02-28-2011, 11:40 AM   #1
rsavage
rsavage's Avatar
3spd to SM 465 Questions
A guy who just bought a 4 WD Blazer with a 6 cyl 3 speed on the column bought my roll bar last week and was saying that he wanted to put a 4 speed in it. I haven't had Chevy six cylinder for forty years, and never in a 4WD Blazer, so I didn't know what to tell him on what he would need. I assume that the bellhousing for his 3 speed would work for the 4 speed correct? Does the transfer case bolt right up to the 4 speed using the same adapter (the 4 speed is out of a two wheel drive Burb) as the 3 speed? What about T case crossmember location and rear driveshaft.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-01-2011, 07:49 AM   #2
Blazer1970
Blazer1970's Avatar
Re: 3spd to SM 465 Questions
No, the pilot hole in the bellhousing is smaller for the three speed.
No, in fact that truck probably has a Dana 20 transfer case and there is no way to hook it to an SM465 with factory parts.
The location and mounting holes are correct, but the crossmember for an SM465/NP205 combo has more drop so that the t-case will clear the floor pan.
What your friend needs to do is sell the 2WD SM465 and buy a complete SM465/NP205 with the bell housing for his swap. He will also have to modify his crossmember or find the correct one.
Blazer1970 is offline   Reply With Quote
Old 03-01-2011, 07:58 AM   #3
rsavage
rsavage's Avatar
Thanks for the info. I appreciate it.
1961 C1 Corvette
2021 Durango RT 5.7
