Old 02-28-2011, 12:32 PM   #1
NC67Chev
NC67Chev's Avatar
How to duplicate the textured paint like on glovebox and dash panel
I'm wanting to paint a piece of steel textured black to look like the glovebox door and the dash cluster. Has anybody figured out a way to do this? Any ideas?
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 02-28-2011, 12:40 PM   #2
Re: How to duplicate the textured paint like on glovebox and dash panel
I did this one in my tow truck with Duplicolor spray-on bedliner. It's close enough for me.
Old 02-28-2011, 12:49 PM   #3
SC C-10
SC C-10's Avatar
You can get a similar look by using a HVLP spray gun. First, lay down a smooth base coat and wait until it starts to flash off or about 10-15 minutes. Then, turn down the air pressure at the gun and spray over the part evenly but keep the gun moving. You will need to have a couple of samples to work with to get the "desired" texture, but this is how I do it.
1969 C-10 short step
1981 CJ7
2017 Ram 2500 Laramie 4X4
1939 Cadillac LaSalle sedan
1950 Allis Chalmers B
1998 Bullet 21 XD 300 Merc/water hot rod
SC C-10 is offline   Reply With Quote
Old 02-28-2011, 01:07 PM   #4
cdowns
cdowns's Avatar
krylon,duplicolor and rustoleum all have wrinkle paint cheap
this oilpan i used krylon because it was on sale at the time
Old 02-28-2011, 01:14 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The wrinkle paint I have used is one that you bake in the oven. Okay on metal, but plastic is gonna have to be treated differently.
Some people have used glove box doors for guage mounts. It could take the heat....
Member Nr. 2770
Old 02-28-2011, 02:01 PM   #6
cdowns
cdowns's Avatar
all three brands i've listed are designed to work on plastic as well as metal// i use a little heat from hair dryer to speed things up or put in hot sunlight to allow wrinkleing naturally// yes on metal it will wrinkle better faster and more extreme if oven or heatlamp cured
Old 02-28-2011, 02:34 PM   #7
NC67Chev
NC67Chev's Avatar
Thanks guys, these are great ideas. I was going to use brushed stainless, but I'm not sure it would "go" with my base model interior. I'll have to go to the store and take a close look at the options.
Old 02-28-2011, 05:26 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
undercoating is another option
Old 02-28-2011, 06:05 PM   #9
69 Okie Truck
69 Okie Truck's Avatar
Use a high nap roller for texture. You're talking about a real tiny part to paint. I'm sure it'd work just fine.
69 Okie Truck is offline   Reply With Quote
Old 02-28-2011, 09:59 PM   #10
I think the dash texture isn't really a wrinkle finish. That's why I did it the way I did. I actually used it on some shocks when I realized it matches the dash texture. It's really simple.
Old 02-28-2011, 10:16 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I think the dash texture isn't really a wrinkle finish....
I agree. That finish is more of a stiple than a wrinkle.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
