need 3 spd Transmission info
I am looking for a transmission for a '52 half ton,. It is a 3 spd column shift and the trans is 14" long. I am told conflicting info. Do you know, does the car trans work or is the imput shaft different? Does the pickup 3 spd take the same clutch disc and pressure plate or are they different? I can find 4 spds but will it take the new spd truck clutch and pressure plate I just bought or does it requirer another size.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. . Last edited by truckdude239; 03-03-2011 at 12:07 AM. Reason: wrong title |
#2 | |
Hollister Road Co.
Re: need 3 spd Transmission info
What is the same is the 2nd-3rd syncro slider, first reverse gear, second gear, input shaft, reverse idler. But they may be different depending on year so you have to count teeth to be sure. Around 54/55 they made the car cases the same as trucks with gearing being a little different and some cars had a short tail shaft and a rear mount and trucks having long tail shafts and no mount. |
If you need any further assistance with that please contact any Admin for help. Last edited by truckdude239; 03-03-2011 at 12:07 AM. |
