Old 03-17-2003, 11:22 PM   #1
Pardue'sCustoms
Pardue'sCustoms's Avatar
is these a good set of heads
3932441
Pardue'sCustoms is offline   Reply With Quote
Old 03-18-2003, 12:01 AM   #2
Nelson
I need to know too! I bought a set that need a little work to replace my 882's!
I believe the 441's 250 hp heads with small spark plug and big chambers.
Please correct me if I'm wrong!
:canada:
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 03-18-2003, 12:09 AM   #3
neonlarry
neonlarry's Avatar
The 441s are what my truck has on it stock. I have seen some tests on ported 441s that wern't to bad though. I would certainly use those over light casting 882s. Someone posted some flow numbers of their mdifyed 441s on the engine and drivetrain board a while ago, and it was pretty good for factory truck heads.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-18-2003, 02:09 AM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
My truck came with 441's stock also. I've got a pair of 350 vortec's that i'm waiting to bolt on to replace the 441's. I just haven't gotten around to it yet.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-18-2003, 02:42 AM   #5
bigjimzlll
bigjimzlll's Avatar
the 441x are 80cc..and are mostly truck heads..the 441s are 75cc i believe and are for 327s and 350s
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
