Wishbone setup help!?!???
I am really wanting to get this setup...http://*******************/4-link-kit...t-wishbone-kit
Problem is, it says I need to measure and figure out my lengths but I'm not sure about what lengths I need. Can someone help me figure out what I'm measuring for? I do know I need to measure for my lower lengths and I think the spread, I'm not to sure though? It's going on a 67 C10 with a 12 bolt, bagged on the trailing arms. I'm going to step notch it and I want to put this wishbone on while I'm notching it but a little worried about not getting the correct sizes. Can anyone help or point me in the right direction? I've done some searching here but nothing really tells me any measurments or even how to measure for them. Any help is appreciated, thanks.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
#2 | |
Re: Wishbone setup help!?!???
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-28-2011 at 07:09 PM. |
I do have a pan hard bar but how is it supposed to keep the rear end centered when i fill and dump the bags? I was under the impression that the only way to fix that is a wishbone or watts link. Keeping my axle centered is one of my main reason for something, be it a watts or wishbone or whatever. I'm not all that knowledgeable about this stuff but I'm learning lol. I would also like something to improve the ride and possibly make it bite ablittle better. I guess a 4 link is good for that? Would a 4 llink be a cure all maybe? I'm trying to learn this stuff to figure out what I need. Thanks again for your help.
Its not for say keeping it centered, its for lateral movement. The longer the panhard the less side shift if has through the air bags travel. A triangulated four link would keep the rear end centered better if properly setup i would say...
The ride has more to do with the position of bags than the link setup.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#5 | ||
A long Panhard bar (~36") will allow very minimal (not noticeable) shift as the suspension cycles through standard travel for most road conditions. So <3" up plus <3" down = 6" total suspension travel when driving. Where it becomes an issue is @ full dump w/air bags (depending on the total amount of lift for ride height). If there's a huge amount of lift from full dump to ride height, there will possibly be .250-.500" shift of the rear end in relation to the frame. We need more info of your set-up to know if a Watts set-up would be better. The factory truck arm 2-link arrangement is simple, rides great (especially on air), & can plant the tires as is. There's several trucks hitting 1.60 60' times @ the track which is a fairly good number given the weight of these trucks. Is a triangulated 4-link better? Define better. Quote:
Well, right now I have an adjustable panhard I got from CPP some time ago. I still have a lot of shift when dumping and filling. It's mounted in the stock location but I was planning on getting a different mount kit, just hope my bar is long enough. Here is what I'm trying to get out of this rear setup. I want to fill and dump without having to worry about it being off centered. I also want to get my bags off of the trailing arms and possible mount them somewhere off the step notch. That should create a better ride correct? I have seen kits that you can get the steps with where they have the bag brakets.
#7 | |
As mentioned, the factory placement of the springs is pretty darn good already for ride quality.... not sure you can improve it much (if any). The only reason to relocate the bags is trying to get lower. What type of bag you're currently using dictates the possible mounting alternatives. That, or you'll need to consider using different bags as well. Whats wrong w/the current ride quality that makes you think the bags need to be relocated?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-01-2011 at 03:37 PM. |
Are you going to use the whole SD rear wishbone kit
nickle and dime Last edited by royo; 03-01-2011 at 06:34 PM. |
I just want something that will really stop the rear shift and possibly help with the ride when I'm going fast. If a longer, relocated panhard will do that then I'm game. I'm super confused now though. What benefit would a watts or wishbone or 4 link give me?
Oh yeah, I might in the future try to Lay frame. Probably won't be for a few years though.
The benefit of a 4link when laying frame would be that you dont have to notch for the trailing arms as the will contact the frame first in most cases. With a longer relocated panhard with the trailing of will handle just fine. Remember Nascar basically uses a truck arm suspension with a panhard bar and they run 200 mph so.....
Hmmmm....I'm going to have to remove my pan hard and see how long it will extend. Around 36" should be fine right? Thanks guys, you guys just made me able to shift my tax money into something else I need for this truck. There is plenty too so everything helps. You guys rock!
#13 |
Yes, Shoot for around 36" long...
#14 |
low n' slo
![]() Join Date: Mar 2009
i think its called deluxe track bar, from cpp. it comes with the double adj. bar, bracket that bolts on the trailing arm, and the small spacer that goes on the driver side ta.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#15 |
Awesome. Thanks guys. I'm going to order them pretty soon. Might check the market first to see if anyone has any specials. Have a good one!
#16 |
Also check w/Rob @ No Limit..... another supporting vendor. He has a really nice set-up as well. You can check it out in one of their threads (NoLimit '72 C-10 or How to Make it Handle).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-02-2011 at 01:56 PM. |
Tags |
measuring |
