Hydro Boost
I had this crazy idea at work today while working on a 2007 2500HD. My BBB only has about 8" of vacumn and thought how cool would it be to put a hydro system on the 71. It doesn't really look that that would be that difficult, but really like to have the power assist braking with the big O girl. So if anybody has done this or has a better idea to make it stop better without breaking the bank please reply.
THANK YOU.
71 C10 2WD,472 Big Block Buick B4B Intake,800 cfm Q-Jet built by(Fred Catlin) Comp Cam 254/268@ .050 .530/542 lift 1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's Mallory fuel system Igniter Flame thrower Ignition system TH350,Hughes 3500 Converter ,3.73's Its just an old heap, but its my hot rod! |
Re: Hydro Boost
Been thinking the same thing for my 68 C20. Theres a newer chevy at my local salvage yard that has the firewall unit still intact. Gotta go get it soon. Then gotta change over to discs front and back. Haven't seen any with all 4 drums using it yet.
Re: Hydro Boost
I've got the same idea in the works for maybe 3 weeks out. I have a hydro booster out of my wrecked 2000 GMC and I've got 4 wheel disc already. I've seen some other posts from folks on here that have done it.
Last time I looked, it didn't seem that difficult. Some modification to the piston push rod to pedal attachment, measuring the correct length from the firewall and such. Probably a good weekend project once all of the hoses are made. Figure on throwing in a new steering box and pump while I'm digging around also.
1968 Chevy C10: 4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Hydro Boost
Member Shaneschevys on here converted his 67 GMC dually to hydroboost. I seem to remember him telling me that some of the existing holes lined right up so he could mark the others and drill them.
Re: Hydro Boost
You mean like this? It's not really all that hard, and they work way better than vacuum boosters.
Re: Hydro Boost
I've wanted to do that on my 71. I had the Hydro boost on my 77 1 ton 4x4 and loved the way it worked and the feel of the pedal.
Re: Hydro Boost
![]() Join Date: Oct 2006
Re: Hydro Boost
Check this guy out. He does ALOT of HB conversions.
http://www.ifsja.org/forums/vb/showthread.php?t=106056
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: Hydro Boost
Re: Hydro Boost
Ls1Nova, looks nice. Hows that AC setup working for you?
Re: Hydro Boost
Thanks Guys
Re: Hydro Boost
#13 |
Re: Hydro Boost
