hydraulic brake help
I don't know anything about hydraulic brakes. It is about the only thing I havn't gone thru or replaced on my 67. Can I pop the lid off of the reservior (did I spell that right), to inspect the fluid and top it up, or will this let air into the lines?. Also , do I use DOT3 brake fluid?
I just finished changing oil pan , tranny pan and filter. I hope I don't have to do this job any time soon again. Well worth it though.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
Cantankerous Geezer
Mountain Man, sounds like y'all need a few lessons in basic shadetree mechanics. To answer your questions. Clean the dirt off the cover, then open the lid. You might need to use a screwdriver as a prybar. Then top off with DOT3 fluid, leaving about 1/4" air space and replace the cover.
Now for the advice. If you haven't, get a factory service manual. It's full of how-to's and pictures and will walk you through a lot of these items. Also, I highly recommend flushing the brake fluid every two years. This involves bleeding the brakes until clean fluid comes out at each wheel cylinder. Brake fluid absorbs water and is easily contaminated, causing rust in your cylinders and brake failure. The brake industry now tells you to flush every year, but they listen to their lawyers too much, in my opinion. ![]()
Fred There is no such thing as too much cam...just not enough engine. ![]() |
You will find this site very helpfull:
http://subtopics.freeyellow.com/Brakes.htm Also, if you need a 1967 Factory Service Manual, I have one for $13.
Just sitting here contemplating contemplation. |
Thats alot of info one one page of the site..............good post...............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
