02-28-2011, 08:06 PM | #1 |
Lowered dually tire options (19 outer, 16 inner)
It's almost time to pull the trigger on some wheels and tires for my lowered dually. I plan to run a 16 inner and a 19 outer which will be cut down from a 19.5 by teneasee wheel & tire. When talking to them they recommended a 245/40-19 and 225/60-16 combo but this only yields a 26.7" overall height compared to a stock 31.5" tire height. With a 4.10 gear I really can't run a 26.7" tall tire so I am thinking about a 245/55-19 and a 235/75-16 which yields a 29.7" height. I also want to run a taller tire so the rim/tire doesn't look lost in the wheel well. What are you guys running for 16/19 or 16/22 combo's? Pictures would be great if you got them. Here is the rim I am thinking of going with. It is an eagle 056
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
03-01-2011, 12:24 AM | #2 |
Re: Lowered dually tire options (19 outer, 16 inner)
I agree w/your tire selection vs. what TnWT has suggested. Their recommended tire combo would work for something super-low, but wouldn't look right on a mild drop.
My math says the inners would be slightly taller (.267"). I'm not sure how critical of a concern that is though. It could prob be diminished w/creative air pressures (little more in the outers, little less on the inners).
03-01-2011, 05:39 PM | #3 | |
03-01-2011, 10:21 PM | #4 |
I may be wrong but weren't people running into issues when towing with their duallies that had two different size wheels (16,19) in the back. If I recall correctly there was some issue with "extreme" tire wear.
Maybe someone else will chime in and correct me if I'm wrong.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
03-02-2011, 08:05 PM | #5 | |
03-02-2011, 08:55 PM | #6 | |
While tire pressure could be adjusted, the question would be how much to yield the 'best' height & will there be any impact as far as sidewall bulge & rubbing concerns between the two closely mounted duals.
03-02-2011, 09:56 PM | #7 | |
03-05-2011, 11:14 AM | #8 |
There must be more people out there running 16/19 combo rear dual wheels??
04-16-2012, 11:03 PM | #9 |
It followed me home?
Ttt
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
04-17-2012, 08:40 AM | #10 |
I will be in the market for a dually soon, can you explain the benefits of this specific swap? Does it prevent rubbing when lowered, or just reduce unsprung weight in the rear?
Love the wheel choice, too Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
04-17-2012, 12:57 PM | #11 |
I ran a 16/19 combo for a while. It is going to eat up some tires. We tried all diffrent combos to resolve this issue with no success. Expect about 8k to 10k out of the tires unloaded. Loaded about 5k to fill safe.
04-17-2012, 01:06 PM | #12 | |
I would like to put bigger diameter wheels on mine but will only run 4 equal size tires. There is no other option for a guy like me w/auto related OCD . I was planning to run 16" steelies w/hub-caps on mine until I started moving the steel wheels around w/more frequency & realized what a BIG difference in weight there is vs aluminum wheels. I would imagine there's a slight weight penalty for the larger diameter aluminum wheels but even they still prob come in @ less than the steelies.
04-17-2012, 08:22 PM | #13 |
talked to American eagle today and the 056 wheel will be out sometime second quarter this year in 20" diameters and will fit two rear aluminum wheels under a lowered truck!! Guess I'll bed waiting a couple months to get tires
04-17-2012, 08:23 PM | #14 |
Any pics and other info on the setup you ran?
04-18-2012, 10:16 AM | #15 |
It's Better With Nitro
I would highly not recommend two different diameter wheels on the rear duals for safety concerns. I've seen many instances of tire failure due to extreme tire wear as mentioned earlier from running a 16" dia wheel on the inners with 19s or 20s on the outers. It may be expensive, but it would be best to run the same size (steel) wheel and tire combination on the inners as the outers...especially if you plan to do any towing or hauling.
04-18-2012, 02:35 PM | #16 |
Check out the Duallyscene. Those guys do it all the time.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
04-18-2012, 04:43 PM | #17 |
Having managed a fleet of trucks in a previous life....the tires on duals needed to be within 3/4" (sometimes less) in circumference and 1/4" diameter of each other and the same series to prevent over flexing and loading of the taller tire, and accelerated wear of both. There are a lot of tire and manufacturer variables involved in trying to match different series tires.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 04-18-2012 at 04:51 PM. |
