Old 03-01-2011, 12:36 AM   #1
Rods57
Rods57's Avatar
78 Chevy Van steering column
I am putting a van tilt column into my 57 chevy truck. Does anyone have pictures of the dis-assembly process? I cant seem to get the turn signal switch out and feel like I am going to break it. Any help would be great....
Rods57 is offline   Reply With Quote
Old 03-01-2011, 01:11 AM   #2
Thadious
Re: 78 Chevy Van steering column
Remove the tilt lever, the screw holding the turn signal lever and it as well, then the hazzard knob. The tin shroud should be worked off at this time (try to avoid bending it, I used a strap wrench (rubber) and just spin it, a little lubricant and it should pop off). Remove the 3 large phillips screws and work the connector out past the lower cone and finally off. It's a pain and real tight.
Good luck!
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 03-01-2011, 01:10 PM   #3
OrrieG
OrrieG's Avatar
When I had to get into my 82 eldo column to remove the lock cylinder I googled and found a couple of sites with detailed disassembly and assembly instruction of GM tilt columns. The sequence is pretty specific and the one plate can be tricky if you don't know how to get it off. I just printed what I needed and do not have the link but remember it popped right up when I searched.
OrrieG is offline   Reply With Quote
Old 03-01-2011, 07:06 PM   #4
Rods57
Rods57's Avatar
Thadious and OrrieG, thanks i will try that out, i have found several sites on the model with the key in the column but very little on mine without. I will post what i find.
Old 03-03-2011, 08:30 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
These should help!
ChuckDriver is offline   Reply With Quote
Old 03-04-2011, 10:41 AM   #6
Rods57
Rods57's Avatar
That's it, i just did not hit it with a hammer yet...
