Old 03-01-2011, 01:58 AM   #1
Tmend
Tmend's Avatar
Need some help
I'm in the process of my fram off resto. My question was I bought cpp 73-87 2 1/2 drop spindles for my 1967. I drove it for a while then started the frame off. I want to buy new upper and lower ball joints do I buy 73-87 upper ball joints or 1967 ball joints also I don't see how I can replace the lower ball joints no bolts or rivets to remove are they replaceable or do I need new control arms thanks guys.
Tmend is online now   Reply With Quote
Old 03-01-2011, 10:28 AM   #2
SCOTI
SCOTI's Avatar
Re: Need some help
Get BJ's for 73-87 spindles.
Lower BJ's are pressed in/out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-01-2011, 11:32 AM   #3
Tmend
Tmend's Avatar
Re: Need some help
okay thanks so bjs for 73-87 ond i should have no problem using those on my stock 67 control arms right Name:  018 (2).jpg
Old 03-01-2011, 11:45 AM   #4
SCOTI
SCOTI's Avatar
Re: Need some help
okay thanks so bjs for 73-87 ond i should have no problem using those on my stock 67 control arms right Attachment 707240
Correct. Also, the arms in your pic above are 73-87 arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2011, 12:03 PM   #5
Tmend
Tmend's Avatar
Re: Need some help
really so they were replaced at one point. thank you very much its good to know what i got now
Old 03-01-2011, 12:04 PM   #6
Tmend
Tmend's Avatar
Re: Need some help
are the bushings hard to change on these
Old 03-01-2011, 01:42 PM   #7
SCOTI
SCOTI's Avatar
Re: Need some help
Hard to do? Not too bad. They're just awkward because of the size & shape of the arm. It takes a little creativity w/a press or using an air chisel/hammer to drive the bushings out on 73-87 a-arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2011, 02:33 PM   #8
Tmend
Tmend's Avatar
Re: Need some help
befor i order them just want to make sure they are the right one input please
Name:  control arm upper.jpg
Old 03-01-2011, 03:38 PM   #9
SCOTI
SCOTI's Avatar
Re: Need some help
The upper in that pic is 73-87. The lower is 6x-72 1/2 ton or 73-87 3/4/1-ton.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2011, 03:48 PM   #10
Tmend
Tmend's Avatar
Re: Need some help
the upper looks the same but the lower looks diff the shaft doesnt look as think and the ends of the shaft are diff bolt vs nut help me out guys
Old 03-01-2011, 04:03 PM   #11
Tmend
Tmend's Avatar
Re: Need some help
so will they work i posted some mor pics of exactly what i got
Old 03-01-2011, 04:34 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Need some help
The pics of the rusty a-arms are 73-87 a-arms.
Keith
Convert to disc brakes.
Old 03-01-2011, 05:15 PM   #13
SCOTI
SCOTI's Avatar
Re: Need some help
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2011, 06:56 PM   #14
Tmend
Tmend's Avatar
Re: Need some help
half ton or 3/4 ton...if i buy the rebuild kit does it make a diff thanks guys
Old 03-01-2011, 07:55 PM   #15
lolife99
lolife99's Avatar
Re: Need some help
Yes.
If you have a 1/2 ton truck,... order 1/2 ton balljoints.
3/4 ton lower a-arms are different.
Keith
