Old 03-01-2011, 10:09 AM   #1
no moa
no moa's Avatar
The difference in the roof lines?
I have a 67 small window cab that has a almost mint roof, my 72 stepside has holes in it, are the roofs the same? They look as if they are, i was going to cut the roof off and use what i need to repair my 72 if thats possible. I know the back windows size will through me off if i used the whole thing.
Just want to be sure before i hack it up.
Thank you
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-01-2011, 10:32 AM   #2
Re: The difference in the roof lines?
Yes,the only part that is different is the back panel and that is just the window. A '67 large window back panel is the same piece as the 68-72. So,everything interchanges...all contours and dimensions are compatible.
