I asked this question in a previous post about the 14 bolt gear ratio. I thought it required a new thread.
What rear would be required to perform this conversion with the result being factory appearing? Meaning I want to use the rear fenders. Does andybody have a width measurement BP to BP for the correct rear? |
BAD BOW-Silverado XST
ponjohn,
I think any 1 ton dually parts from 73-91 should bolt on. I've seen a 87-91 blazer converted to a dually rear!!! It was for sale. If I see it again I'll take a picture of it. If the dually will bolt to a Blazer the rear ends should bolt to a truck. The easiest conversion is to find a dually bed. The fenders are availble but you would have to put them on yourself. ------------------ Gerardo 1983 Custom Truck TX Plates: "BAD BOW" |
ponjohn,
That would be great. I have seen suburbans converted to, ends up being a nice package. You say the fenders are still available, is the from GM?
I beleive the pickup rear is wider than the cab/chassis? Thanks, john |
I do not know all the #'s But I know that there are at least 3 different 14 bolt rears
single wheel cab & chassis dual wheel pickup I also believe the spring hangers are different and the shock mounts are as well ------------------ 72 3/4 lwb fleet 427 t350 4x4 under construction
'96 GMC Suburban 6.5t '99 F**d Windstar '07 SON '09 DAUGHTER XOXOXO Wife |
![]() prices for the adapters were 449.50 shipping included. I bought them through T.E.A. 1-800-500-0497, or 1-713-644-0497 i bought the bed for 600.00 and spent about 400.00 on the parts for the front end, that includes the parts for new bushings and ball joints from Auto Zone. Hope this helps later dave
1976 Crew Cab Dually (under construction) 1972 Suburban 1955 Pro Street Chevy 1985 S-10 Blazer (daily driver) V W Sandrail Located in Horn Lake, MS that's just 4 miles south of Memphis TN www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm Former engine builder for Racing Head Service Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!! GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!! |
