03-01-2011, 12:56 PM | #1 |
More power?
I have a 1972 c/10 with the 350 ci and the 350 tranny, and i was wondering what where some cheep ways to put a little more pep in its step, Mind you, i'm a high school senior and i'm a little straped for cash. thanks guys.
1972 Chevy C/10 Custom Deluxe 1973 Chevy C/10 Custom Deluxe Bowties for life Last edited by Bowtie1216; 03-01-2011 at 12:57 PM. |
03-01-2011, 01:58 PM | #2 |
Re: More power?
1. HEI, Plugs and Wires
2. Chrome Valve Covers 3. Intake and Carb Upgrade 4. Camshaft 5. Bigger Exhaust (keep manifolds) 6. Trans Shift Kit |
03-01-2011, 02:16 PM | #3 |
Old Skool Club
Re: More power?
Similar question on the '88-98 page.
An internal combustion engine is an air pump. If you want to get more out of it, you have to think about getting more air into it, through it and back out. You gotta have an air filter, if you want your engine to live. But, a low-restriction air filter (K&N, for example) will help. If you are running a 2-bbl carb, you're limited as to how much air can be introduced. A proper 4-bbl carb and intake will make a difference. To get the exhaust out of the engine, you need a free-flowing system. Whether it is headers, or just keeping your cast iron manifolds, a dual exhaust system with an X-pipe (at least a cross-over tube), will give you the flow that it needs. Cams and such are good, but until the intake and exhaust is able to handle it, you're getting the cart before the horse.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-01-2011, 02:31 PM | #4 |
the boat guy
Re: More power?
chrome valve covers lol!
what are the specs on your 350 now. Carb intake, ompresion ratio. Has your engine been tuned lately, does it need a complete tune up? How many miles are on the engine and transmission. Have you dropped the trans pan to change filter and fluid, was the bottom of the pan clean or did it have a bunch of silt in the bottom. theirs nothing like spendin a bunch of money on making more power just to start breaking stuff you cant afford to replace. Best to start with simple tune up and make sure everything is in good working order.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
03-01-2011, 03:10 PM | #5 | |
Re: More power?
1972 Chevy C/10 Custom Deluxe 1973 Chevy C/10 Custom Deluxe Bowties for life |
03-01-2011, 03:14 PM | #6 |
Re: More power?
The biggest band for the buck is going to be Carb and Distributor dial in tune up. Once these are done then it's time to change parts if your budget allows. Never a good idea to start changing parts, except for maybe chrome valve covers, before you have a good clean optimized baseline.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
03-01-2011, 03:18 PM | #7 |
Re: More power?
One more thing, could i get a link of where i could one of those air filters i'm been looking and i can't find it lol
03-01-2011, 03:43 PM | #8 | |
Re: More power?
jegs.com some napa's I'd start with a tune up.. does it have hei already?? if not new points if needed and set the timing, check to see if the advance is working (mechanical and vacuum) you said it has a 4 barrel on it.. what one (q jet/holley/etc) mecanical secondary or vacuum) with someone in truck and it off, air cleaner off,, mash the gas , the throddle blades should be standing straight up.. is the choke pulling compleatly off,, start with what will cost you zero.. get a timing light and a vacuum gauge and tune it up.. you'll be shocked on just how much is in it, that a tune up will bring back.. |
03-01-2011, 08:52 PM | #9 |
Re: More power?
I second the vote for a good tuneup. The first upgrade I would make is an HEI. You don't have to spend a lot of money one one- mine cost less than $25 from a pick-n-pull. New plugs, wires, and a carb tune should give you a good starting point. Change the oil if you haven't done it already.
With 140,000 miles, you've got some carbon and wear on the valves, which means in my book that it's not going to be worth replacing the cam unless you do the valves too. Since you're on a budget, I'd just get it running well and save money until you can afford to do the upgrades you want. |
03-01-2011, 11:09 PM | #10 |
Re: More power?
HEADERS!!!! made a ton of diff in my truck
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
03-02-2011, 12:11 AM | #11 |
Re: More power?
Thanks guys
1972 Chevy C/10 Custom Deluxe 1973 Chevy C/10 Custom Deluxe Bowties for life Last edited by Bowtie1216; 03-02-2011 at 01:09 AM. |
03-02-2011, 06:53 PM | #12 |
Re: More power?
You all laugh at the chrome valve covers but once he pulls the old ones he will see what the top end looks like and chick dig chrome things.
03-02-2011, 08:16 PM | #13 |
454 MAKES IT ROAR
Re: More power?
They sure do...and fury dice!
Another informative thread and funny too..I love ths place.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
03-02-2011, 10:37 PM | #14 |
Re: More power?
lol
03-02-2011, 11:58 PM | #15 |
Grandpa in the rustmobile...
Re: More power?
Check out the highschooler thread im a senior too, do ya DD your truck? Lets see some pix
http://67-72chevytrucks.com/vboard/s...d.php?t=334086
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
