Old 03-01-2011, 08:16 PM   #1
rano
76 Dana 44 Steering Arm
I just picked a set of 76 Chevy 4x4 axles to put under my 55 pickup to replace some early 60s 4x4 axles. The front axle is a Dana 44 and the steering arm is missing. I need new studs, cone washers and nuts also. The stock arm would be within about 1-1/2" of the height if the pitman arm so an arm for a 4" plus lift will not work. Where can I find a stock arm, studs, cone washers and nuts?
1955 Chevy 2nd Series Pickup, 4x4, 4 speed, from Arizona
1955 Chevy 210 Delray 283, 4 speed and 55 posi, old street racer
1967 Chevy Corvette 427/435 hp numbers matching, Top Flight
1973 Ford Bronco Hunting Rig
rano is offline   Reply With Quote
Old 03-01-2011, 08:55 PM   #2
71blazerdetroit
Re: 76 Dana 44 Steering Arm
Everything but the arm , offroad design.
Then again, worth asking them if they have a stock arm laying around.
71blazerdetroit is offline   Reply With Quote
Old 03-01-2011, 10:25 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Might need to go to a boneyard to pull one. Most that lifted a truck and installed the raised arm threw the old arm in the trashcan. I know I did.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-03-2011, 07:10 PM   #4
rano
The studs are out. Found new studs, cones and nuts at Independent4x. Now working on finding a stock arm 73-78.
Old 03-04-2011, 09:07 AM   #5
I'd post a WTB in the parts board. Let someone else do the hard work of pulling it . Someone who installed a raised arm will have the stock one laying around. And,they were happy to pull it off to get their truck lifted
Old 03-04-2011, 02:04 PM   #6
OldCreek
OldCreek's Avatar
I'm pretty sure I've got a stock arm from my 71 K5 laying around at my barn. I held onto it in case I wanted to go back to stock height. It should be the same.
I'm not planning on heading over to the barn anytime soon, though. So, it may take a week or so to get it.... You could have it for the cost of shipping.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-04-2011, 02:05 PM   #7
OldCreek
OldCreek's Avatar
Btw, I highly recommend cross over steering...but if you've no lift...
Old 03-05-2011, 09:05 AM   #8
rano
The knuckle steering arm I am looking for is GM #3979552 and is used from 1973-78 on 1/2 ton Dana 44s.
Old 03-08-2011, 09:05 AM   #9
duallyjams
duallyjams's Avatar
Do you have to be a supporting member to post a WTB ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-08-2011, 09:10 PM   #10
rano
Found a guy locally that has a stock arm he will sell me.
