03-01-2011, 08:20 PM | #1 |
Show me pics of C10's with 22inch wheels!!!
I'm currently in the process of buying some 22's for my 67 C10. I'm concerned about the fitment and tire sizes. I need to see what I'm working with. help me out my fellow truckers!!!! Show me dem 22's!!!!
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
03-02-2011, 10:50 AM | #2 |
Restoration Virgin!
Re: Show me pics of C10's with 22inch wheels!!!
ttt....let see them 22's
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
03-02-2011, 12:14 PM | #3 |
needs more $$$
Not a truck, but my blazer on 22's.
Bags in place of coils. Wheels are 22x9.5 with 15 mm offset. Front tires are 265/35 rears are 295/30.
1970 2wd Blazer |
03-02-2011, 12:30 PM | #4 |
Only have the rears on mine, haven't got around to taking the front inner fenders out yet
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast" 68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger" Last edited by Jparks; 03-02-2011 at 12:31 PM. |
03-02-2011, 12:39 PM | #5 |
heres mine with 22's all the way around
1967 C-10 Project 2008 Suburban 2017 GMC Sierra |
03-02-2011, 12:44 PM | #6 |
Here is mine! not the best pic but 22" on the back 3" notch on air ride.
1972 c/10 Custom, Long Box, 350 Small Block, Auto 3 Speed, Custom Wood box, Full Air Ride, 3" C-Notch, 20" Front & 22" Rear Tires, Snow White Paint, PT Crusher Handles, |
03-02-2011, 01:44 PM | #7 |
03-02-2011, 01:49 PM | #8 |
Sofa King Crazy!!
22s out back.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-02-2011, 03:27 PM | #9 |
Colin i bought the set of clips that go along with the caps, made a pattern, then drilled and tapped the rims, I'll take a picture of it later
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast" 68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger" |
03-02-2011, 09:07 PM | #10 |
What is your tire size and how low are you dropped?
03-02-2011, 10:54 PM | #11 |
tires are 265/35/22 all around.
i have 3 inch drop springs in front and 5 inch drop springs in rear. also have 2 inch lowering blocks in rear but i dont have my wood bed in yet so it mite sit a little lower, not sure.
03-02-2011, 10:59 PM | #12 |
What about drop spindles???
03-02-2011, 11:05 PM | #13 |
03-02-2011, 11:35 PM | #14 |
They are centerline smoothies, painted satin black in the centers with 55 chevy hubcaps also painted satin black in the center
03-02-2011, 11:36 PM | #15 |
i have new stock spindles up front that i purchased when i did the disc brake upgrade. my truck was pretty riding pretty low since the PO heated the springs so i wanted to bring it up a bit.
btw, just checked out your build thread. Truck looks awesome! ill be watching for that painless install since those are in the plans for my build.
1967 C-10 Project 2008 Suburban 2017 GMC Sierra Last edited by SBC; 03-02-2011 at 11:46 PM. |
03-03-2011, 12:13 AM | #16 | |
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: Last edited by Orangetonicclicc; 03-03-2011 at 12:14 AM. |
03-03-2011, 12:58 AM | #17 |
i did the swap a couple years ago but if i remember right i used POL, mainly because they are based in CA so the parts get here fast. i am very happy with their products so far (also got a rear mounted tank from them)
i kept the rear drum brakes and just did a drum rebuild on them at the same time, also from POL. i didnt put the 22's on until after the swap but i have never had any rubbing issues in front. i did have to use a spacer on the rear but pretty sure that was just because of the rims i chose. (backspacing i guess)
04-07-2011, 07:42 PM | #18 |
Does anyone have pics of a 83 longbed with 22s out back 20s up front lowered.
04-25-2015, 02:56 AM | #19 | |
Posted via Mobile Device |
04-26-2015, 03:26 PM | #20 |
Here is my new project 68 C10 with 22" Lorenzo WL14 #454 rim frt. & back, Nitto NT 420S tires, rims are 10" deep with tire mounted over all width is 11.5" each mounted rim & tire is 89.6 lbs. The trucks inner tubs are missing my thoughts on that is the tires are too wide for the opening and they do rub if going over bumps too fast. PO has installed twist coil extenders two ea. coil, the back drums have 1 1/2" spacers for that fitment and again they also rub, PO he says installed Jeep coils but I'am not so sure on the coils being Jeep, they fit too good for the mounting brackets, The stance is a bit on the high side truck measures from frt. of cab 13.5" & at the rear of cab 15". This is NOT my cup of tea but I sure didn't buy it for the rims & tires its well you all know its that Beautifully Designed Front End that catches our eyes. mjgord51
04-26-2015, 06:30 PM | #21 |
22x8.5
22x10
Eric K |
04-26-2015, 08:08 PM | #22 |
02-22-2019, 09:53 AM | #23 |
07-02-2019, 09:49 AM | #24 |
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
07-03-2019, 12:28 AM | #25 |
I’ve seen a “show me your 22s” “show me your lip” but what I want to know is, What does it take to get 22s with big lips. I have a 60” WMS rear and was wondering what kind of lip I could get with 22s.
