Stupid question of the year
My truck is a stock 68, drum brakes all around and not altered in any major way other than paint. If I bought 4 tires of the same height and width, would the front ones stick out past the fender edge more than the rear? (Assuming the rear line up perfectly with the edge of the fender.)
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Stupid question of the year
Yes.
The track width of the front is slightly wider than the rear track width.
Even on the 2WD?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
i think the 2wd is even front and rear.
horsepower sells cars torque wins races. "caroll shelby" |
yes 2wd and 4wd trucks front tires stick out wider than the back it isnt very noticeable but if you look for it you will see it
My front is about 3 inches wider than the rear. I have an ECE 4/6 drop so I wasn't sure if the spindles were what pushed them out or if it was like that originally.
'67 C10 |
Thanks for the data. My next question is WHY??? I know its not a big deal but it is enough to bother me, you can see it in the pics thread but I thought it might be a camera angle. What is the engineering advantage and more importantly how can I fix it?? I have heard talk of offsets. Do I need discs to fix it? Either way would work for me, push the rears out to match or fronts in to match. Please help me understand my options. Thanks.
FYI - It only bothers me because I can't stand uneven things, especially on the one vehicle that comes so close to perfection for me with its lines as this one does. Last edited by ubtripn; 03-02-2011 at 09:44 AM. |
it helps the car/trucks track straight,
I see. Still nothing like leaving 4 separate tire tracks in the snow (or in the is case wider ones.) That's not what bothers me though, its just the uneveness.
Thanks for the information. Last edited by ubtripn; 03-02-2011 at 10:23 AM. |
Yeah, what he said. The wider front helps with stability and straightness. Ever see those 3-wheeled street cars? They have 2 wheels up front and one in the back. That's a very exaggerated case of the front being wider than the rear, but it works. Ever see those old 70's cars with stock size front tyres and super wide rears? They also didn't handle as well. Not to mention that they jacked 'em way up in the rear, reducing caster up front!
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
That example helped me understand the physics of it.
#13 |
Does anyone know how I can make them even while running the same size tire?
#14 |
Add spacers to the rear wheels.
#15 |
Thanks!
#16 |
needs more $$$
lolife's is the simplest and cheapest way to get it done, but man, if that bothers you, the fact that the wheels aren't in the center of the wheel wells must be killer!
If you ever switch to discs in the front, it's just going to get worse to since they push them out about a half in on each side.
1970 2wd Blazer |
#17 |
![]() Join Date: Jan 2001
#18 |
You guys are funny, I get ribbing for what seems to be a small thing while there are others who are worried about period correct chalk markings on the firewall =) I guess we all have our own quirks or goals, mine is symmetry.
And thanks TubbedII, I hadn't noticed that till you said that. Hah! No solving that one. Well, at least its not as bad as my 66 where the front wheel wells are higher than the rear =) Thanks again for the fix =) Last edited by ubtripn; 03-02-2011 at 10:02 PM. |
#19 |
Happy to be here
![]() Join Date: Mar 2000
If it makes you feel better, I suffer from the same syndrome. I don't know what its called, but unsymmetrical things really bother me.
#20 |
Lol - it does.
#21 |
yes, i do
its an O.C.D type. just like people that have to have their pants fly, belt buckle and button up shirt perfectly lined up at all times. the navy beats that O.C.D. into your head at boot camp. now when i wear a tucked in button up shirt, pants and a belt they all have to be perfectly in line or it bothers the fork out of me.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#22 |
Old Skool Club
![]() Join Date: Jun 2001
Well then....the early Sixties had a custom trend that embodied assymetrical styling. Think Ed Roth.....Mysterion. Barris built one that had a slant 6 plymouth engine. There were a bunch, back then. Did I like 'em? They had their place in the automotive world, but I knew I'd never own one. The Art Deco style is more to my liking.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#23 |
blood type; Retumbo
I think I would let it go. hard to see the wheels when sitting in the truck
#24 |
Dave's not here, man
OCD for sure....although, my girlfriend and I call it CDO because we like for the letters to be in alphabetical order...the width differences have always bugged me too, so you aren't alone
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#25 |
Drives me crazy also.
That's why I alway run a wider wheel on the rear.
