Old 03-01-2011, 10:23 PM   #1
denny5625
denny5625's Avatar
My REAREND IS TOOOOO WIDE
I'm sure this has been brought up before but I'll bring it up again.I have a 5 lug 12 bolt rearend (half ton) that I would like the narrow 1 1/2 inches on each side. No problem there. My question is can the axles be shortened and still have enough spline for them to work? Also the c clips. Can the axle be re-notched fr the clips? Thanks.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 03-01-2011, 10:33 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: My REAREND IS TOOOOO WIDE
I have the same problem(too much beer & pizza) At any rate, I am not sure about the stock axles, but Moser can set you up with the proper lenght C clip axles that you need. The set in my 12 bolt were $260 with studs, & you cant buy much machine shop time for that crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-01-2011, 10:50 PM   #3
denny5625
denny5625's Avatar
Thats not bad at all. Did you order those direct from Moser? Thanks
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
Old 03-01-2011, 10:53 PM   #4
crazy longhorn
Yes I did. Service was promt too
Old 03-01-2011, 10:59 PM   #5
denny5625
denny5625's Avatar
Sweet. Thanks for your input.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
Old 03-01-2011, 11:16 PM   #6
crazy longhorn
Thats been 2-3 yrs back, so prices may have changed somewhat. crazyL
Old 03-02-2011, 10:00 PM   #7
denny5625
denny5625's Avatar
I called them today. They said 341.00 shipped to my door. Pretty cheap.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
