Old 03-01-2011, 11:42 PM   #1
Vandals909
Trailblazer SS engine?
Has anyone used one for a swap? Theres a pretty good deal on a trailblazer ss engine with 4l70e trans.
It has a different intake manifold, exhaust manifold, accessory mounting and also has a belt driven fan. The accessories I was told mount like the chevy trucks. Oh ya also the oil is different.
Anyone have any experience with this engine in a c10?
I'm just worried that i might run into problems not having a vette, gto or camaro engine.
Vandals909 is offline   Reply With Quote
Old 03-01-2011, 11:46 PM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: Trailblazer SS engine?
iirc i think the ss trailblazers had ls2s in them.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-02-2011, 12:31 AM   #3
Vandals909
Yes it is an LS2, but the intake, exhaust manifolds, accessories and oil pan are all different, just wondering if I will run into a lot of problems using this engine vs a vette, camaro or gto engine?
Old 03-02-2011, 01:15 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
for the oil pan I would use this http://www.jegs.com/i/GM-Performance...ductId=1221210 it comes with every thing you need for the swap. The exhaust manifolds will work well
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-02-2011, 01:26 AM   #5
Vandals909
Thanks Flaming. What about intake with hood clearance? Issues with accessories being in different order?
Old 03-02-2011, 09:29 AM   #6
flamingbig10
6.0 powered square
the intake and drive accessory will work just fine
Aaron
Old 03-07-2011, 11:41 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Agreed. The TB SS engine will work just fine. Maybe just have to swap oil pan. i believe those have the high mount a/c compressor so no frame clearance issues either. Wish I had a TB SS LS2 instead of my 6.0 LS out of a 01 truck.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-19-2011, 09:40 PM   #8
shenk10
shenk10's Avatar
I have a build thread on here with one, mine was out of a awd so I have to change the trans and had to swap the oil pan, I used the one that flamingbig10 mentioned and it worked fine. All accesories are the same as the truck engines except the power steering. The trucks power steering tank is a little bit different and might have to be swapped to a truck one, I haven't got my engine mounted yet to know for sure but seems like it might be a problem. The stock manifolds will work fine. I'd just make sure it's a 2wd rather than an awd, because it requires a lot more work and money. If you have any questions just ask.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 03-19-2011, 09:48 PM   #9
TR65
TR65's Avatar
Vandal,
I am running a 6.0 LS2 out of a 2005 SSR which is made on the Trailblazer platform. Mine has the low mount AC compressor which I am using but it took some work. I used a late model truck oil pan and it fit fine in the truck. The Trailblazer exhaust manifolds hug the motor closer than the standard truck ones and fit great. I had to change the PS pump to a remote tank. Plenty of hood clearance. I am using the stock SSR tune with a few tweaks. I even used the cats and exhaust system all the way to the back of the cab.
You will love it. Good luck.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
