Old 03-02-2011, 09:18 AM   #1
kellytheaker
72 valve covers
i have a 72 350 4+4 and the valve covers are edelbrock and wish to return it to stock - the coorect valve covers would be helpfull and possibly a pictur ewould help for the fill tube and other questions . the fill tube i have seen are from the usual small turn cap to a 6 " high fill that comes off the cover and has a support . i would appreciate any help that you have to offer
kellytheaker is offline   Reply With Quote
Old 03-02-2011, 01:26 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 72 valve covers
Anybody got pictures of stock 350 valve covers
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-02-2011, 03:51 PM   #3
kcsa75
kcsa75's Avatar
Re: 72 valve covers
By '72, GM had pretty much moved away from oil filler tubes in the manifold. As a result, most factory valve covers had three holes -- two for emission control and one to add oil.
Check out Summitt Racing or Jegs. They each have OEM type valve covers available.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 03-02-2011, 04:57 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 72 valve covers
this is what I get from summit.....but I'm pretty sure somebody has pictures of stock valve covers
Geoff with a G
Old 03-02-2011, 05:22 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 valve covers
a 4X4 had a fill tube on the cover with a brace as the OP described. I used to have a photo but I lost it in a nasty computer death.
Old 03-02-2011, 06:06 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 72 valve covers
I had a 72 that had an oil fill tube in the valve cover. I have seen the for sale in the classifieds.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-02-2011, 06:46 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 72 valve covers
I have set of valve covers from a 72 gmc 350 they were hot tanked and I did a chevy orange spraypaint job on them I'll get some pictures if you wanna
John
1999 Toyota Tacoma 4x4
Old 03-02-2011, 07:59 PM   #8
rsavage
rsavage's Avatar
Re: 72 valve covers
I think they would be similar to my 70 and 71
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-02-2011, 08:15 PM   #9
kellytheaker
Re: 72 valve covers
excellent , so i am to think the long fill neck is normal for both 2 and 4 wheel and this is what i should be picking up ? or was the fill just a cap on the cover ? thanks to all replying
Old 03-02-2011, 08:49 PM   #10
rsavage
rsavage's Avatar
Re: 72 valve covers
I believe that the tall fill tube had to do with having power brakes (booster & MC in the way) as opposed to 2 wheel or 4 wheel drive. My Burb was non power brakes stock and just had a fill cap on the valve cover.
1961 C1 Corvette
2021 Durango RT 5.7
Old 03-02-2011, 08:53 PM   #11
navysnipe
navysnipe's Avatar
Re: 72 valve covers
I have a 72 K20 and the valve covers were really crappy. It has the 350 and I want to keep it as stock as possible. I ordered these from summit;
http://www.summitracing.com/parts/TRD-9916/
made by Trans-Dapt Performance Products 9916 - Trans-Dapt Performance OEM Reproduction Colormatch Valve Covers and they are exactly like the originals even the powdercoat is very close to the original orange. I have had them side by side and looks like they were stamped by the same machine.
good luck
Navysnipe
navysnipe is offline   Reply With Quote
Old 03-02-2011, 08:53 PM   #12
kellytheaker
Re: 72 valve covers
makes sense , looking for a set now , this should not to be bad . i just wanted the correct answer on the fill stack or not and why helps . it just so happens i have pwr brakes . so i suspect it is the 6" fill and brace i need as well - thanks
